coq-club - [Coq-Club] simpl doesn't perform reduction
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] simpl doesn't perform reduction
  • Date: Sun, 03 May 2015 15:56:21 +0300
Could anyone explain why simpl fails to perform reduction here? Is it
because of the Eq typeclass?
Fixpoint is_in_order_merge {X : Type} {eq_x : Eq X} {eq_list : Eq (list X)}
(l1 l2 l : list X) : bool :=
match l1 with
| [] => eqb l2 l
| (x::xs) =>
match l2 with
| [] => eqb l1 l
| (y::ys) =>
match l with
| [] => false
| (z::zs) =>
if eqb x z
then is_in_order_merge xs l2 zs
else if eqb y z
then is_in_order_merge l1 ys zs
else false
end
end
end.
Theorem is_iom__iom :
forall {X : Type} {eq_x : Eq X} {eq_list : Eq (list X)} (l1 l2 l : list X),
is_in_order_merge l1 l2 l = true -> in_order_merge l1 l2 l.
Proof.
induction l1 as [|x xs].
Case "l1 = []".
intros.
simpl in H.
(* XXX: no simplification is performed in H. *)
(* Case := "l1 = []" : String.string *)
(* X : Type *)
(* eq_x : Eq X *)
(* eq_list : Eq (list X) *)
(* l2 : list X *)
(* l : list X *)
(* H : is_in_order_merge [] l2 l = true *)
(* in_order_merge [] l2 l *)
(* subgoal 2 (ID 1555) is: *)
(* forall l2 l : list X, *)
(* is_in_order_merge (x :: xs) l2 l = true -> in_order_merge (x :: xs) l2 l
Abort.
