- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Printing not in sync with parsing
- Date: Thu, 07 May 2015 10:57:01 -0400
On 05/07/2015 10:32 AM, Cedric Auger wrote:
> Such a notation is clearly not revertible, and can still be considered
> useful.
> Thus the only hint I can provide is "first request your IDE to stop hiding
> stuff, then print, then copy/paste, then restore the printing state of the
> IDE".
> Maybe that within a IDE, a thing which could be considered is to have a
> "copy as reparsable" in the IDE menu, which would automatically do this.
> That does not seem trivial at all to have a useful feature from this.
Speaking from the IDE implementation side, I think there's a legitimate use
case for such a feature: lemma extraction. `company-coq` already implements
this on top of Proof-General: you press a key, specify the hypotheses that
you want to keep, and it inserts a new (selected hypotheses + dependencies ->
goal) lemma for you.
I often come across cases where I have a bunch of useless hypotheses and a
few relevant ones, as part of a larger proof. In these cases I like to pull
out the relevant hypotheses and the goal into a separate lemma, that I can
just use in conjunction with [eauto using] in the larger proof. For example:
p : nat
q : nat
r : nat
H : p < q < r
H0 : p + q < q + r
H1 : exists s : nat, p + q + r < s
n : nat
m : nat
IHm : n + m = m + n
n + S m = S m + n
In this case I want to get the following lemma generated automatically:
Lemma subgoal:
forall n m : nat, n + m = m + n -> n + S m = S m + n.
company-coq already has a feature to do this automatically (C-c C-a C-x)
based on a sequence of [generalize dependent] and [clear]), but it breaks
when printing-only notations are in used in the display of the goal. Some
sort of [Set Printing Reparsable] option would be a very welcome addition in
this case; the other printing options are tricky to fine-tune automatically.
Clément.
- [Coq-Club] Printing not in sync with parsing, Gert Smolka, 05/07/2015
- Re: [Coq-Club] Printing not in sync with parsing, Cedric Auger, 05/07/2015
- Re: [Coq-Club] Printing not in sync with parsing, Clément Pit--Claudel, 05/07/2015
