- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] proofs involving 'match' constructs
- Date: Fri, 29 May 2015 17:13:11 -0400
Here's a shorter, more ad-hoc, proof:
Require Import Vector.
Require Import ArithRing.
Goal match mult_n_O 0 in (_ = y) return (t (option nat) y) with
| eq_refl => nil (option nat)
end = nil (option nat).
Proof.
generalize (mult_n_O 0).
simpl.
set (z := 0) at 2.
change (nil (option nat)) with (Vector.const (@None nat) z) at 2.
change 0 with z at 2.
clearbody z.
intros []; reflexivity.
Defined.
On Fri, May 29, 2015 at 3:53 PM, Amin <amintimany AT gmail.com> wrote:
Oh wait, It seems I haven’t been paying close enough attention. In this case as e is equality over type nat, UIP does in fact hold for it (as equality for nat is decidable) and thus we can prove this lemma as follows:Require Import Vector.Require Import ArithRing.Require Import Coq.Logic.JMeq.Require Import Coq.Arith.Peano_dec.Program Fixpoint ScatHUnion_0 {A} {n:nat} (pad:nat): t A n -> t (option A) ((S pad)*n) :=match n return (t A n) -> (t (option A) ((S pad)*n)) with| 0 => fun _ => @nil (option A)| S p => fun a => cons _ (Some (hd a)) _ (append (const None pad) (ScatHUnion_0 pad (tl a)))end.Next Obligation.ring.Defined.(* code from EqFacts.v in the gist link in the other email *)Section Eq_Facts.Variable A : Type.Definition K := forall (x : A) (P : x = x -> Prop), P eq_refl -> forall (eq : x = x), P eq.Definition URIP := forall (x : A) (eq : x = x), eq = eq_refl.Definition UIP := forall (x y : A) (eq eq' : x = y), eq = eq'.Definition eq_rect_eq := forall (x : A) (P : A -> Type) (eq : x = x) (p : P x), p = eq_rect x P p x eq.Definition projT2_eq := forall (x : A) (P : A -> Type) (p q : P x), existT P x p = existT P x q -> p = q.Lemma K_URIP : K -> URIP.Proof.intros k x eq.apply (k _ (fun p => p = eq_refl) eq_refl).Qed.Lemma UIP_UIP : URIP -> UIP.Proof.intros urip x y eq eq'.destruct eq'.apply urip.Qed.Theorem UIP_eq_rect_eq : UIP -> eq_rect_eq.Proof.intros uip x P eq p.rewrite (uip _ _ eq eq_refl); trivial.Qed.Theorem eq_rect_eq_projT2_eq : eq_rect_eq -> projT2_eq.Proof.intros ere x P p q H.set (proj1_eq := fun (v : sigT P) (H : existT P x p = v) => match H in _ = z return projT1 (existT P x p) = projT1 z with eq_refl => eq_refl end).assert (H' : match (proj1_eq (existT P x q) H) in _ = u return P u with eq_refl => projT2 (existT P x p) end = projT2 (existT P x q)).{destruct H; trivial.}cbv in ere.rewrite <- (ere _ _ (proj1_eq _ H)) in H'; trivial.Qed.Theorem projT2_eq_k : projT2_eq -> K.Proof.intros p2 x P H eq.cut (eq = eq_refl); [intros H'; rewrite H'; trivial|].apply p2; destruct eq; trivial.Qed.Section Dec.Hypothesis A_dec : forall a b : A, {a = b} + {a <> b}.Definition make_eq {a b : A} (eq : a = b) : a = b.Proof.destruct (A_dec a b) as [H|H].+ exact H.+ exact (False_rect _ (H eq)).Defined.Theorem make_eq_const : forall {a b : A} (eq eq' : a = b), make_eq eq = make_eq eq'.Proof.intros a b eq eq'.cbv.destruct A_dec as [H|H]; trivial.destruct (H eq).Qed.Theorem make_eq_com_sym : forall {a b : A} (eq : a = b), eq_trans (eq_sym (make_eq (eq_refl a))) (make_eq eq) = eq.Proof.intros a b eq.destruct eq.destruct (make_eq eq_refl); trivial.Qed.Theorem k : K.Proof.intros x P H eq.rewrite <- make_eq_com_sym in H.rewrite <- make_eq_com_sym.replace (make_eq eq) with (make_eq (eq_refl x)); trivial.apply make_eq_const.Qed.End Dec.End Eq_Facts.(* End of code from EqFacts.v *)Lemma URIP_nat : URIP nat.Proof.apply K_URIP.apply k.apply eq_nat_dec.Qed.Lemma test0: @ScatHUnion_0 nat 0 0 (@nil nat) = (@nil (option nat)).Proof.cbv.generalize (mult_n_O 0); intros e.cbn in e.rewrite (URIP_nat 0 e).trivial.Qed.On 29 May 2015, at 21:34, Amin <amintimany AT gmail.com> wrote:Hi,This lemma is in fact (without help of some axioms) not provable in Coq. That said, here is a solution that uses an axiom (JMeq_eq). I explain the problem below.Require Import Vector.Require Import ArithRing.Require Import Coq.Logic.JMeq.Program Fixpoint ScatHUnion_0 {A} {n:nat} (pad:nat): t A n -> t (option A) ((S pad)*n) :=match n return (t A n) -> (t (option A) ((S pad)*n)) with| 0 => fun _ => @nil (option A)| S p => fun a => cons _ (Some (hd a)) _ (append (const None pad) (ScatHUnion_0 pad (tl a)))end.Next Obligation.ring.Defined.Lemma test0: @ScatHUnion_0 nat 0 0 (@nil nat) = (@nil (option nat)).Proof.cbv.generalize (mult_n_O 0); intros e.cbn in e.(*At this point you will have:e : 0 = 0============================match e in (_ = y) return (t (option nat) y) with| eq_refl => nil (option nat)end = nil (option nat)As you see the problem now would be solved if we could just replace e with eq_refl (i.e., destruct e.)This is impossible though. This is because doing a case analysis on e would require us to considerthe general case where e is replaced by e’ : 0 = x for a general x. This on the other makes the goalill-typed.The problem boils down to the fact that in coq you can’t prove unicity of identity proofs (or any other axiom equivalentto it, e.g., JMeq_eq I used).Using JMeq_eq changes eq to JMeq which due to its heterogeneity does not become ill-typed undersuch an abstraction as above.*)apply JMeq_eq.destruct e.trivial.Qed.Here is a short Coq script proving equivalence of some axioms that are equivalent to UIP (unicity of identity proof) and JMeq_eq:Regards,AminOn 29 May 2015, at 20:21, Vadim Zaliva <vzaliva AT cmu.edu> wrote:I am wondering what is a good approach to trying to prove some things like this:
end.
Next Obligation.
ring.
Defined.
(This definition works only under Coq 8.5. Under 8.4 I had to define it differently).
I stuck proving the following trivial lemma:
I could not get much further than:
test0 < compute.
1 subgoal
Any suggestions how to deal with proving constructs like this?
Thanks!
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- [Coq-Club] proofs involving 'match' constructs, Vadim Zaliva, 05/29/2015
- Re: [Coq-Club] proofs involving 'match' constructs, Amin, 05/29/2015
- Re: [Coq-Club] proofs involving 'match' constructs, Jason Gross, 05/29/2015
- Re: [Coq-Club] proofs involving 'match' constructs, Laurent Théry, 05/29/2015
