coq-club - [Coq-Club] Is rewrite_strat with hints broken in 8.4?
  • From: Mario Alvarez <mariomcgilvrayalvarez AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Is rewrite_strat with hints broken in 8.4?
  • Date: Thu, 4 Jun 2015 17:19:51 -0700
Hello, Coq Club,
I want to use rewrite_strat to do some rewriting under binders. Upgrading to 8.5 is not currently a realistic option for my project, so I'm using 8.4(pl4).
Ideally I'd like to use a hint database for this rewriting. However, I've had some problems trying to do this:
- The "hints" directive in rewrite_strat seems to be broken; when I use it with my hints database it complains that there's nothing to rewrite, even when there is clearly rewriting to be done.
- Looking at the source code, I saw there's an "old_hints" directive. This one seems to work for most of the rewriting hints I care about.
- However, old_hints doesn't quite take care of everything. Some of my hints don't generate side-conditions and are simple rewriting lemmas. These seem to be applied correctly. However, I have some lemmas which produce side-conditions; these need to be discharged using a separate Resolve hint-database. In particular, I have
Hint Rewrite
     embed_push_TRUE embed_push_FALSE
     embed_push_And embed_push_Or embed_push_Imp
     embed_push_Exists embed_push_Forall
     embed_push_Const
  : embed_push.
(* these ones produce side-conditions *)
Hint Rewrite
     embed_push_Eq embed_push_Gt embed_push_Le
     using solve [eauto 20 with arith_push]
                         : embed_push.
Hint Resolve
     arith_push_plus arith_push_VarNow arith_push_VarNext arith_push_Nat_zero arith_push_Nat_one arith_push_Nat arith_push_Real
  : arith_push.
I apply these hints using
rewrite_strat (topdown (old_hints embed_push)).
With the second "Hint Rewrite" command commented out, this works correctly (except that it doesn't do the rewriting specified in the second "Hint Rewrite" command, which I need).
When I uncomment the second batch of hints, no rewriting is performed at all. Instead I get the following error message:
Error: Application of lemmas whose beta-iota normal form contains
metavariables deep inside the term is not supported; try "refine" instead.
Do you know if there is a way to get this behavior (using rewrite_strat to rewrite under binders, with the ability to discharge side-conditions using a Resolve database) in 8.4?
Thanks,
Mario
  • [Coq-Club] Is rewrite_strat with hints broken in 8.4?, Mario Alvarez, 06/05/2015
