coq-club - [Coq-Club] Error: U is bound to a notation that does not denote a reference.
  • From: Christian Doczkal <doczkal AT ps.uni-saarland.de>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Error: U is bound to a notation that does not denote a reference.
  • Date: Wed, 03 Jun 2015 21:46:47 +0200
Hello Everyone,
I sometimes use "Local Notation" to hide arguments that remain constant
throughout a section. A contrived minimal example would look as follows:
Require Import ssreflect.
Definition U {T} (s : list T) := app s s.
Section Foo.
Variables (T:Type) (x : T).
Local Notation U := (U (cons x nil)).
Lemma foo : length U = 1 -> False.
As a preprocessing step before calling an automation tactic, I want to
unfold all occurrences of U. However, using "unfold U in *" fails.
Ssreflect's "rewrite /U" succeeds in unfolding U, but requires explicit
naming of all hypothesis, which I'm trying to avoid.
Proof.
intros H.
(* unfold U in *. *)
(* Error: U is bound to a notation that does not denote a reference. *)
(* rewrite /U in * *)
(* Error: assumptions should be named explicitly *)
rewrite /U in H. (* unfolds (U (cons x nil)) *)
Abort.
I tried using the following piece of Ltac:
Ltac unfold_U :=
(repeat progress match goal with
| [H : context[U] |- _] => rewrite /U in H
end); rewrite /U.
This works for the particular U defined above. If I try to abstract "U",
I get the same error as when calling "unfold U in *"
Is there anything else I can do? (This is on Coq 8.4)
Regards
Christian
