- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is eq_refl = mult_n_O 1 provable?
- Date: Mon, 08 Jun 2015 11:38:33 -0400
On 06/08/2015 11:25 AM, Adam Chlipala wrote:
If some type has decidable equality, then all proofs of the same equality in that type are provably equal. See this module from the standard library:
https://coq.inria.fr/stdlib/Coq.Logic.Eqdep_dec.html
In other words:
Require Import Peano_dec.
Lemma fobar: eq_refl = mult_n_O 1.
apply UIP_nat.
Qed.
It is also popular to assert as an axiom that all proofs of some equality are equal, though in general that property is independent of Coq's logical theory, I believe. If you'd like to import that axiom (not needed for your example, since equality on [nat] is decidable), see here:
https://coq.inria.fr/stdlib/Coq.Logic.Eqdep.html
On 06/08/2015 11:21 AM, Lars Rasmusson wrote:
Hi,
this might be trivial, but how would one prove this lemma?
The left side is of type 0 = 0 and the right side is of type 0 = 1 * 0.
Is the left side equal to the right side, or only of coercible types?
As the type eq only has one constructor, shouldn't that make them the same?
- [Coq-Club] Is eq_refl = mult_n_O 1 provable?, Lars Rasmusson, 06/08/2015
- Re: [Coq-Club] Is eq_refl = mult_n_O 1 provable?, Adam Chlipala, 06/08/2015
- Re: [Coq-Club] Is eq_refl = mult_n_O 1 provable?, Jonathan Leivent, 06/08/2015
- Re: [Coq-Club] Is eq_refl = mult_n_O 1 provable?, Lars Rasmusson, 06/08/2015
- Re: [Coq-Club] Is eq_refl = mult_n_O 1 provable?, Daniel Schepler, 06/08/2015
