coq-club - Re: [Coq-Club] Snoc list recursion principle
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Snoc list recursion principle
  • Date: Mon, 15 Jun 2015 16:33:30 +0200
Hi, would this help?
Pierre
Require Import List.
Section rev.
  Variable A:Type.
Function rev' (l : list A) : list A :=
  match l with
  | nil => nil
  | x :: l' => rev' l' ++ x :: nil
  end.
Check rev'_rect.
Check rev'_equation.
2015-06-15 15:25 GMT+02:00 Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>:
Dear all, and especially experts in dependent types / computations with identity proofs.
I am trying to write a snoc list (aka reverse list) recursion
principle *with its associated fixpoint equations*.
There is a snoc list induction principle in the standard library
(check rev_ind in List.v) but there are no associated fixpoint
equations (because it is an induction principle in Prop).
I would like to obtain something like:
Definition snoc X l (x:X) := l++x::nil.
Notation "l '\\' x" := (snoc l x) (at level 59, left associativity).
(* dependently typed snoc recursion principle *)
Section list_rev_rect.
  Variable (X : Type) (P : list X -> Type).
  Variable Pnil  : P nil.
  Variable Psnoc : forall l x, P l -> P (l\\x).
  Definition list_rev_rect : forall l, P l.
  Admitted.
  Fact list_rev_rect_nil : list_rev_rect nil = Pnil.
  Admitted.
  Fact list_rev_rect_snoc l x :
       list_rev_rect (l\\x) = Psnoc x (list_rev_rect l).
  Admitted.
End list_rev_rect.
I have some code developed towards this end. Mainly you have
to make identity proofs transparent and carefully compute
equations between identity proofs  but I get stuck at some
point with too complicated equations.
May be there is some easy solution that I am unaware of. I could
post my partial developments for this problem if my question
turns out to be non trivial.
Thank you very much in advance,
