- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Snoc list recursion principle
- Date: Tue, 16 Jun 2015 17:49:30 +0200
Hi,
I din’t try to prove comp_snoc_refl below but I guess it is not directly
provable in Coq (requires some axioms). As you mentioned working with proofs
of equalities is usually very cumbersome. Here is my attempt at defining
list_rev_rect, list_rev_rect_nil and list_rev_rect_snoc:
Require Import Coq.Lists.List.
Require Import Coq.Logic.JMeq.
Definition snoc {X} l (x:X) := l++x::nil.
Notation "l '\\' x" := (snoc l x) (at level 59, left associativity).
(* dependently typed snoc recursion principle *)
Definition rev_lem : forall {A : Type} (l : list A) (a : A), rev (l ++ a ::
nil) = a :: (rev l).
Proof.
induction l.
reflexivity.
intros a'.
cbn.
rewrite IHl.
trivial.
Defined.
Definition RI : forall {A : Type} (l : list A), rev (rev l) = l.
Proof.
induction l.
reflexivity.
cbn.
rewrite rev_lem.
rewrite IHl.
trivial.
Defined.
Definition RI_snoc : forall {A : Type} (l : list A) (x : A) (H : rev (rev l)
= l), rev (rev (l\\x)) = (l\\x).
Proof.
intros A l x H.
unfold snoc.
rewrite rev_lem.
cbn.
rewrite H.
trivial.
Defined.
Section list_rev_rect.
Variable (X : Type) (P : list X -> Type).
Variable Pnil : P nil.
Variable Psnoc : forall l x, P l -> P (l\\x).
Definition list_rev_rect : forall l, P l.
Proof.
intros l.
rewrite <- RI.
induction (rev l) as [|h rl].
assumption.
cbn.
apply Psnoc.
trivial.
Defined.
Fact list_rev_rect_nil : list_rev_rect nil = Pnil.
Proof.
trivial.
Qed.
Fact list_rev_rect_snoc l x :
list_rev_rect (l\\x) = Psnoc _ x (list_rev_rect l).
Proof.
unfold list_rev_rect.
unfold list_rect, eq_rect.
apply JMeq_eq.
destruct (RI l).
destruct (RI (rev (rev l) \\ x)).
etransitivity.
rewrite (RI l).
unfold snoc.
rewrite rev_lem.
trivial.
trivial.
Qed.
End list_rev_rect.
I didn’t spent much time on it. list_rev_rect is defined by a proof and can
be simplified by hand. Note that I have here used JMeq_eq which is an axiom.
Regards,
Amin
> On 16 Jun 2015, at 14:54, Dominique Larchey-Wendling
> <dominique.larchey-wendling AT loria.fr>
> wrote:
> Dear Pierre,
> Thanks for your hint. However I did try to apply the list_rect
> recursion principle on the reverse list (rev l) but I get the
> same problems as the one that occur in the following code.
> Mainly, the problem is concentrated in the proof of
> comp_snoc_refl l y x : comp_snoc y (l\\x)
> = existT _ x (exist _ (y :: l) eq_refl)
> which states that 2 identity proofs are identical ... if
> you destruct the list l several times, "auto" succeeds on the "nil"
> case each time and leave the "cons" case open.
> Thus I think this goal is provable by induction on l but
> managing proofs of equality of identity proofs is horribly
> painful. In particular, the unification algorithm of Coq
> fails most of the time so you have to enter terms by
> hand ...
> Thank you anyway for your hint but to me, it does not seem
> to solve the problem I am interested in, which is obtaining
> the 3 following results :
> list_rev_rect, list_rev_rect_nil and list_rev_rect_cons
> Best regards,
> Require Import Arith.
> Require Import List.
> Require Import Wf.
> Require Import Wellfounded.
> Set Implicit Arguments.
> Notation "l '\\' x" := (l++x::nil) (at level 59, left associativity).
> Section list_utils.
> Variable X : Type.
> Fact app_assoc (l m k : list X) : (l++m)++k = l++(m++k).
> Proof.
> induction l as [ | x l ]; simpl.
> reflexivity.
> rewrite IHl; reflexivity.
> Defined.
> Fact snoc_length l (x : X) : length (l\\x) = S (length l).
> Proof.
> rewrite app_length, plus_comm; auto.
> Qed.
> Fixpoint last (x : X) l :=
> match l with
> | nil => x
> | y::l => last y l
> end.
> Fact last_snoc x l y: last x (l\\y) = y.
> Proof.
> revert x; induction l; intros; simpl; auto.
> Defined.
> Fixpoint beg (x : X) l :=
> match l with
> | nil => nil
> | y::l => x::beg y l
> end.
> Fact beg_snoc x l y : beg x (l\\y) = x::l.
> Proof.
> revert x; induction l as [ | a ? IH ]; intros; simpl; auto.
> rewrite (IH a); reflexivity.
> Defined.
> Fact beg_last_snoc x l : (beg x l)\\(last x l) = x::l.
> Proof.
> revert x; induction l as [ | y ? IH ]; intros x; simpl.
> reflexivity.
> specialize (IH y).
> rewrite <- IH.
> apply (app_assoc (x::nil)).
> Defined.
> Fact snoc_inj_beg l l' (x x' : X) : l\\x = l'\\x' -> l = l'.
> Proof.
> intros H.
> generalize (beg_snoc x l x) (beg_snoc x l' x').
> rewrite H; clear H; intros H; rewrite H.
> injection 1; auto.
> Defined.
> Fact snoc_inj_last l l' (x x' : X) : l\\x = l'\\x' -> x = x'.
> Proof.
> intros H.
> rewrite <- (last_snoc x l x), <- (last_snoc x l' x').
> f_equal; assumption.
> Defined.
> Definition comp_snoc (x : X) l : { y : _ & { l' | l'\\y = x::l } }.
> Proof.
> exists (last x l), (beg x l).
> apply beg_last_snoc.
> Defined.
> Fact comp_snoc_refl l y x : comp_snoc y (l\\x) = existT _ x (exist _ (y ::
> l) eq_refl).
> Proof.
> unfold comp_snoc.
> (* It is difficult to prove that equation but the following
> tactic succeed i.e. it leaves only one goal *)
> do 10 (destruct l as [ | ? l ]; auto).
> (* hence an inductive proof on l should be feasible but I get stuck
> with unmanageable equations between equality proofs *)
> Admitted.
> Definition snoc_dec (ll : list X) : (ll = nil) + { x : _ & { l | l\\x = ll
> Proof.
> destruct ll as [ | x l ].
> left; reflexivity.
> right; apply comp_snoc.
> Defined.
> End list_utils.
> Let snoc_rel (l m : list X) := exists x, m = l\\x.
> Let wf_snoc_rel : well_founded snoc_rel.
> Proof.
> intros l.
> induction l as [ | x l IH ] using rev_ind.
> constructor.
> intros [] (? & H); discriminate H.
> constructor.
> intros m (y & Hm).
> apply snoc_inj_beg in Hm.
> subst; assumption.
> Qed.
> Let F l (f : forall m, snoc_rel m l -> P m) : P l.
> Proof.
> destruct (snoc_dec l) as [ H | (x & m & H) ]; subst.
> apply Pnil.
> apply Psnoc, f.
> exists x; auto.
> Defined.
> Definition list_rev_rect := Fix wf_snoc_rel _ F.
> Fact list_rev_rect_fix l : list_rev_rect l = F (fun m _ => list_rev_rect
> m).
> Proof.
> unfold list_rev_rect at 1.
> rewrite Fix_eq; auto.
> clear l.
> intros l f g H; unfold F.
> destruct (snoc_dec l) as [ | (x & m & H')]; subst;
> unfold eq_rect_r; simpl; f_equal; auto.
> Qed.
> Proof.
> rewrite list_rev_rect_fix; unfold F.
> auto.
> Qed.
> Let snoc_dec_refl (x : X) l : snoc_dec (l\\x) = inr (existT _ x (exist _ l
> eq_refl)).
> Proof.
> unfold snoc_dec.
> destruct l as [ | y l ];
> simpl; auto.
> f_equal.
> apply comp_snoc_refl.
> Qed.
> Fact list_rev_rect_snoc l x : list_rev_rect (l\\x) = Psnoc x
> (list_rev_rect l).
> Proof.
> rewrite snoc_dec_refl; auto.
> Qed.
> End list_rev_rect.
> Print Assumptions list_rev_rect_snoc.
- [Coq-Club] Snoc list recursion principle, Dominique Larchey-Wendling, 06/16/2015
- Re: [Coq-Club] Snoc list recursion principle, Amin Timany, 06/16/2015
- Re: [Coq-Club] Snoc list recursion principle, Dominique Larchey-Wendling, 06/16/2015
- Re: [Coq-Club] Snoc list recursion principle, Dominique Larchey-Wendling, 06/17/2015
- Re: [Coq-Club] Snoc list recursion principle, Matthieu Sozeau, 06/17/2015
- Re: [Coq-Club] Snoc list recursion principle, Daniel Schepler, 06/16/2015
