- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq CPU recommendations
- Date: Tue, 16 Jun 2015 16:58:17 -0400
The [abstract] tactical provides a generic way of reducing that
memory overhead, by periodically forcing all of the closures into
proof terms. It can have major effects on memory usage. On 06/16/2015 01:32 PM, Timothy
Carstens wrote:
I think the issue is that the tactics engine builds loads of closures as it tries things out. (Is that right?) If so, that's hard to meaningfully optimize, unless there's a systemic way to make far fewer of 'em. On Jun 16, 2015 10:17 AM, "Eric Mullen"
<emullen AT cs.washington.edu>
wrote:
I've discovered myself writing proofs differently in
order to make them run faster/use less memory. I wonder
if it would be possible to develop a tactic optimizer (a
la query optimizer from DB) which could optimize a long
chain of semicolon strung together tactics to run
Mostly I've found that simpl is slower than you think, and
firstorder is almost always a terrible idea.On Tue, Jun 16, 2015 at 10:12 AM Timothy
Carstens <intoverflow AT gmail.com>
wrote:
Maximize your cache and get a CPU that supports quad-channel DDR, as there's symbolic things going on. Either Xeon (not worth it unless you are going for max parallelism) or an i7-extreme (which is a Xeon with some cores fuse-disabled). I have run out of memory with 64GB installed, so YMMV. On Jun 16, 2015 10:05 AM, "Eric
Mullen" <emullen AT cs.washington.edu>
wrote:
I have a dedicated coq machine with an
i7-4790K and 16g of ram. It works quite well
in practice. Additionally, at UW, we're
developing an emacs mode which allows you to
edit proof files located on your machine,
but running coqtop to process the files on a
remote server. We'll post to this mailing
list when it's a bit more stable.
In general I'd recommend getting an i7-4790K
and at least 8g of ram (16 seems to have been
overkill). You might also want to look into
overclocking, you can push the i7-4790K up to
5gHz in some cases. I've heard good things
about http://siliconlottery.com/
if you're interested in buying a processor for
overclocking.On Tue, Jun 16, 2015 at 9:22 AM
Benjamin Barenblat <bbaren AT mit.edu>
wrote:
-----BEGIN
PGP SIGNED MESSAGE-----Hash: SHA512 Hi all, Does anybody have recommendations for hardware that runs Coq especially well? I would like Coq to run as quickly as possible using standard, commercial off-the-shelf hardware like Intel’s i7-4790K. I’m also curious about Coq’s CPU cache usage. When Coq runs slowly, is it actually CPU-bound, or is it bound by RAM bandwidth? Thanks in advance, Benjamin -----BEGIN PGP SIGNATURE----- iQF8BAEBCgBmBQJVgEwyXxSAAAAAAC4AKGlzc3Vlci1mcHJAbm90YXRpb25zLm9w ZW5wZ3AuZmlmdGhob3JzZW1hbi5uZXQ5OThCQjVEMTlDOEE3QjE3OUUwREFCODY5 RTczMDE0OUVCOTFDNTNCAAoJEJ5zAUnrkcU73iIH/iHru9cbiHYPhtBmL577KNhg hU4dyLHKeBbp4jocj+k5UbxMIvW1HS8QSyEVzN2RzzhSd+YHhIjE7My0qnnycRpk VqzijnfeKl4m8IHmbi2+WhstZzVp9wWnE9+3HDc3XJV8IGYv2gyAALuy2ma43JmS RJnqB5m+s4mvejsPCGWkIUxzlIdSi4uarC2WrkFE2vkASgObSc7mBmTLV2iqNmfT ELaEKYHyWMwBfOGgEgAieoAf4lkz70uKNo/oIRLl53ANIR2X9RbTJboEKxZMMNUk eu1oVXQeVKKy+mOyCmPexYTXRzl+0WIhjWdz3SO6b3f7ee9TsfwQ2V8EOjaRGSQ= =qWuU -----END PGP SIGNATURE----- |
- [Coq-Club] Coq CPU recommendations, Benjamin Barenblat, 06/16/2015
- Re: [Coq-Club] Coq CPU recommendations, Eric Mullen, 06/16/2015
- Re: [Coq-Club] Coq CPU recommendations, Timothy Carstens, 06/16/2015
- Re: [Coq-Club] Coq CPU recommendations, Adam Chlipala, 06/16/2015
- Re: [Coq-Club] Coq CPU recommendations, George Van Treeck, 06/16/2015
- RE: [Coq-Club] Coq CPU recommendations, Soegtrop, Michael, 06/17/2015
- Re: [Coq-Club] Coq CPU recommendations, Enrico Tassi, 06/17/2015
- Re: [Coq-Club] Coq CPU recommendations, Matthieu Sozeau, 06/17/2015
- Re: [Coq-Club] Coq CPU recommendations, Adam Chlipala, 06/17/2015
- Re: [Coq-Club] Coq CPU recommendations, Timothy Carstens, 06/17/2015
- Re: [Coq-Club] Coq CPU recommendations, Pierre-Marie Pédrot, 06/18/2015
- Re: [Coq-Club] Coq CPU recommendations, David MENTRE, 06/18/2015
