- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq computationally exploding on me
- Date: Sat, 27 Jun 2015 16:14:15 +0200
On 27/06/2015 09:52, Chris Dams wrote:
Dear all,>
I was doing a proof where I used
destruct (Nlt_ge_dec (i + j) (2 ^ 32)) as a tactic.
At this point it is clear why the Qed never finishes.
No, it is not that clear. The kernel does not normalize a proof term when checking it at Qed, unless you explicitly asked for it through a tactic such as vm_compute. Otherwise the following script would never go through:
Goal fact 99 * 100 = 100 * fact 99.
Proof. apply mult_comm. Qed. (* OK *)
But whether the kernel unfolds a definition or not is a heuristic unfortunately. And it might happen that the kernel always unfolds the worst definition, thus ending up normalizing the proof term.
Goal fact 99 * 100 = fact 100.
Proof. exact_no_check (mult_comm (fact 99) 100). Qed. (* Fail *)
Here, for some reason, the kernel thought that unfolding mult was making more sense then unfolding fact. So, in addition to the solution you already suggested, you can also help the kernel deciding which definitions should be unfolded first.
Strategy 1 [ mult ]. (* set mult at priority 1, so that it has a lower priority than fact, which is at priority 0 by default *)
Proof. exact_no_check (mult_comm (fact 99) 100). Qed. (* OK *)
Best regards,
Guillaume
- [Coq-Club] Coq computationally exploding on me, Chris Dams, 06/27/2015
- Re: [Coq-Club] Coq computationally exploding on me, Guillaume Melquiond, 06/27/2015
- Re: [Coq-Club] Coq computationally exploding on me, Chris Dams, 06/29/2015
