- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Automatically adding casts
- Date: Wed, 1 Jul 2015 10:11:55 -0700
All,
I am wondering if anyone has any ideas about getting Coq to insert casts into
terms, either fully automatically or with some tactics and/or an OCaml module
to process terms into a form that allows this. I imagine this sort of thing
was part of the deduction modulo work; did this require some serious changes
to the Coq kernel, or is it something that could be done with an OCaml
module? Martin Hofmann also did something like this in his dissertation, but
I am not sure if it has been implemented in a system like Coq…?
The specific case I am interested in is where I have zero or more equalities
between a free variable and a term that does not contain that free variable.
For example, I would like to be able to enter something like the following,
and have it type-check:
Program Definition foo (T: Set) (T__eq: T = nat) (f: T -> T) : nat :=
f 5.
One idea I had was to replace every occurrence of f with a cast to an unknown
type using evars in place of T, as in something like the following:
((rew ?e1 in f) : ?T1 -> ?T2)
Any idea if this sort of thing would work? Or does anyone have any other
suggestions?
Any help along these lines would be greatly appreciated.
-Eddy
- [Coq-Club] Automatically adding casts, Eddy Westbrook, 07/01/2015
- Re: [Coq-Club] Automatically adding casts, Adam Chlipala, 07/01/2015
- Re: [Coq-Club] Automatically adding casts, Eddy Westbrook, 07/01/2015
