- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Understanding Rewriting
- Date: Wed, 8 Jul 2015 22:35:12 -0700
I don't know about merlin, but you can use Ltac pattern matching and "type of" to conveniently find out types of sub-expressions.
(Don't worry if you don't know what Ltac is.)
When your goal was
lengthy_match = negb negb legthy_match
You could use the following to find the type of the RHS lengthy_match:
match goal with
[ |- _ = negb (negb ?x)] => let ty:= (type of x) in idtac ty
end.
Here is a concrete example:
Goal 2+3=99.
match goal with
[ |- ?x = _] => let ty:= (type of x) in idtac ty
end.
If/when you are reasonably comfortable with Coq, you can look under-the-hood at:
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Wed, Jul 8, 2015 at 10:13 PM, Kenneth Adam Miller <kennethadammiller AT gmail.com> wrote:
Wow! I literally just thought of that a few minutes before reading this. I had done this silly thing:assert (neg_neg: forall x, negb (negb f x) = f x).introducing only the new forall, but not eliminating the unnecessary f.It appears that what I was struggling with here is a more clear understanding of the typing of sub-components of my expressions. Is there anything like emacs' merlin but for Coq? I'm using proof general already. Had I known that the match statement's type was not compatible I would have been more quick to recognize the issue.Thanks so so much, that one hint really pushed me over the hump.On Thu, Jul 9, 2015 at 12:58 AM, John Wiegley <johnw AT newartisans.com> wrote:>>>>> Kenneth Adam Miller <kennethadammiller AT gmail.com> writes:
> assert (neg_neg: negb (negb (f n)) = f n).
> Basically, I get to a part where I have to show:
Have you tried generalizing your helper lemma?
assert (neg_neg: forall x, negb (negb x) = x).
It may not be applying for you because you've proven something too specific.
John
- [Coq-Club] Understanding Rewriting, Kenneth Adam Miller, 07/09/2015
- Re: [Coq-Club] Understanding Rewriting, John Wiegley, 07/09/2015
- Re: [Coq-Club] Understanding Rewriting, Kenneth Adam Miller, 07/09/2015
- Re: [Coq-Club] Understanding Rewriting, Abhishek Anand, 07/09/2015
- Re: [Coq-Club] Understanding Rewriting, Jonathan Leivent, 07/09/2015
- Re: [Coq-Club] Understanding Rewriting, Vadim Zaliva, 07/10/2015
- Re: [Coq-Club] Understanding Rewriting, Pierre Courtieu, 07/10/2015
- Re: [Coq-Club] Understanding Rewriting, Clément Pit--Claudel, 07/10/2015
- Re: [Coq-Club] Understanding Rewriting, Emilio Jesús Gallego Arias, 07/10/2015
- Re: [Coq-Club] Understanding Rewriting, John Wiegley, 07/10/2015
