coq-club - Re: [Coq-Club] Understanding Rewriting
  • To: Emilio Jesús Gallego Arias <gallego AT cri.ensmp.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Understanding Rewriting
  • Date: Sat, 11 Jul 2015 18:54:44 +0200
Hi,
On Fri, Jul 10, 2015 at 01:04:22PM +0200, Emilio Jesús Gallego Arias wrote:
> Abhishek Anand
> <abhishek.anand.iitg AT gmail.com>
> writes:
> > I don't know about merlin, but you can use Ltac pattern matching and "type
> > of" to conveniently find out types of sub-expressions.
> I have also found quite useful ssreflect's
> "set f := pattern"
> tactic to find out types of tricky sub-expressions; the matching
> mechanism usually works well for my full-of-holes patterns.
> I don't know if this can be done with the standard Coq tactics.
Coq standard "set" supports patterns. In Kenneth's example you can
do for instance:
Fixpoint evenb n :=
match n with
| O => true
| S 0 => false
| S (S n) => evenb n
end.
Theorem even_n__oddb_Sn : forall n : nat,
evenb n = negb (evenb (S n)).
Fixpoint f (n0 : nat) := (match n0 with
| 0 => false
| S n' => evenb n'
end).
Proof.
intros; elim n; intros; simpl in |- *; auto. rewrite H . simpl in |- *.
assert (neg_neg: negb (negb (f n)) = f n).
elim f. simpl. reflexivity. simpl. reflexivity.
set (a:= match _ with 0 => _ | _ => _ end).
a = negb (negb a)
or even directly
destruct (match _ with 0 => _ | _ => _ end).
2 subgoals
n, n0 : nat
H : evenb n0 = negb (evenb (S n0))
neg_neg : negb (negb (f n)) = f n
true = negb (negb true)
subgoal 2 is:
false = negb (negb false)
Best,
Hugo Herbelin
