- From: Frédéric Besson <frederic.besson AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Dumb question about dep. pattern matching
- Date: Wed, 15 Jul 2015 21:08:14 +0200
Hi,
Your code is working with 8.5beta2.
Set Printing All shows the code provided by James.
Print produces:
nT =
fix nT (n : nat) : Type :=
match n with
| 0 => unit
| 1 => Type -> Prop
| S (S _ as n0) => ((Type -> Prop) * nT n0)%type
end
: nat -> Type
Best,
Frédéric
> On 15 Jul 2015, at 20:39, Beta Ziliani
> <beta AT mpi-sws.org>
> wrote:
> I'm ashamed to ask this, I'm pretty sure this was answered somewhere.
> I'm trying to do a (what I thought was a) simple dependent function type nT
> and function of that type fT. More concretely, nT generates types [unit,
> Type->Prop, (Type->Prop)*(Type->Prop), ...]:
> Fixpoint nT n : Type :=
> match n with
> | 0 => unit
> | 1 => Type -> Prop
> | S n => ((Type -> Prop) * nT n)%type
> end.
> When I try to define the function fT, it fails:
> Fail Fixpoint fT n : nT n :=
> match n with
> | 0 => tt
> | 1 => (fun T:Type=>True)
> | S n' => ((fun T:Type=>True), fT n')
> end.
> Failing with message:
> Recursive call to fT has principal argument equal to
> "S n0" instead of one of the following variables:
> "n'" "n0".
> Even if I try to help Coq a bit with annotations, or even breaking the
> cases, it's the same: it is not considering n = S n'. The only way I found
> to deal with this is using Program (avoiding it to perform the
> substitutions!):
> Obligation Tactic := idtac.
> Program Fixpoint fT n : nT n :=
> match n as m return n = m -> nT m with
> | 0 => fun _ => tt
> | S n' => fun H1 =>
> match n' return n = S n' -> nT (S n') with
> | 0 => fun _ =>(fun P:Type => True)
> | S n'' => fun H2 => ((fun P:Type => True), (_ (fT n') : nT (S n'')))
> end eq_refl
> end eq_refl.
> Next Obligation.
> intros; rewrite H1 in H2.
> injection H2; intro H'.
> rewrite H' in x.
> exact x.
> Defined.
> Next Obligation.
> auto.
> Defined.
> which is horrible. Anyone knows of a better way to define this?
> Thanks,
> Beta
> P.S.: A simpler version fails in a weird way:
> match n return nT n with
> | 0 => tt
> | S n' =>
> match n' as m return n' = m -> nT (S m) with
> | 0 => fun _ => ((fun T:Type=>True) : nT 1)
> | S n'' => fun H2 => _ ((fun T:Type=>True), fT n')
> end eq_refl
> end.
> Next Obligation.
> intros.
> rewrite <- H2.
> simpl.
> rewrite H2.
> rewrite <- H2.
> exact x.
> Fail Defined.
> Error: Error: Illegal application:
> The term "@pair" of type
> "forall (A : Type@{Coq.Init.Datatypes.23})
> (B : Type@{Coq.Init.Datatypes.24}), A -> B -> A * B"
> cannot be applied to the terms
> "Type@{Top.1610} -> Prop" : "Type@{max(Set+1, Top.1610+1)}"
> "nT n'" : "Type@{Top.1319}"
> "fun _ : Type@{Top.1610} => True" : "Type@{Top.1610} -> Prop"
> "fT n'" : "nT n'"
> The 1st term has type "Type@{max(Set+1, Top.1610+1)}"
> which should be coercible to "Type@{Coq.Init.Datatypes.23}".
- [Coq-Club] Dumb question about dep. pattern matching, Beta Ziliani, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, James Wilcox, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, Beta Ziliani, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, Frédéric Besson, 07/15/2015
- Re: [Coq-Club] Dumb question about dep. pattern matching, Frédéric Besson, 07/16/2015
