- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] ML extraction: annotated functions
- Date: Thu, 23 Jul 2015 17:45:39 -0300
Thanks for your answers but I guess I didn’t express myself clearly, since the problem I’m pointing out is not addressed.
(background: while I’m clearly not an OCaml expert, I do know about parametric polymorphism, type theory, basic Coq usage, and the documentation about extraction.)
I found a very minimal example that makes my point (I’m in Coq 8.5beta2):
Test.v
Require Import String ExtrOcamlString.
Extraction "append.ml" append.
This yields the following definitions:
in append.ml
(** val append : char list -> char list -> char list **)
let rec append s1 s2 =
match s1 with
| [] -> s2
| c::s1' -> c::(append s1' s2)
in append.mli
As you can notice, append in append.ml has a _more general inferred_ type than what it is meant to have:
$ ocaml -init append.ml
OCaml version 4.02.1
# append;;
- : 'a list -> 'a list -> 'a list = <fun>
This means that for instance, the _expression_ `append [] []' in append.ml has type ‘a list, instead of having type char list.
so if you add that to the .ml file:
let x = append [] [];;
print_endline x
the compiler complains:
File "append.ml", line 13, characters 14-15:
Error: This _expression_ has type 'a list
but an _expression_ was expected of type string
So the extra polymorphism that is granted by leaving the type implicit in append.ml is a double-edged sword. Can be helpful, but can be problematic.
In a larger development (no idea why the problem does not reproduce with a more minimalist file), the mismatch between the .ml file and the .mli file even prevents compilation:
$ ocamlc foo.mli
$ ocamlc foo.ml
File “foo.ml", line 1:
Error: The implementation foo.ml
does not match the interface foo.cmi:
Values do not match:
val append : 'a list -> 'a list -> 'a list
is not included in
File “foo.ml", line 59, characters 8-14: Actual declaration
I have noticed that extraction to Haskell *does* include the type information *for real* (ie. not as a comment).
append :: char list -> char list -> char list
append s1 s2 =
case s1 of {
[] -> s2;
(c : s1') -> c : (append s1' s2)}
Doing the same in OCaml would prevent the issues I describe above.
Is that clearer?
Thanks,
— Éric
- [Coq-Club] ML extraction: annotated functions, Éric Tanter, 07/23/2015
- Re: [Coq-Club] ML extraction: annotated functions, Kenneth Adam Miller, 07/23/2015
- Re: [Coq-Club] ML extraction: annotated functions, Robbert Krebbers, 07/23/2015
- Re: [Coq-Club] ML extraction: annotated functions, Éric Tanter, 07/23/2015
