- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Qualified imports
- Date: Tue, 11 Aug 2015 10:13:32 +0200
2015-08-11 8:37 GMT+02:00 N. Raghavendra <raghu AT hri.res.in>:
At 2015-08-10T10:24:52Z, Soegtrop, Michael wrote:
> maybe there is a more elegant way, but what I did sometimes in such
> cases is to wrap it into a module like this:
> Module L.
> Require List.
> Include List.
> End L.
> Print L.hd.
Thanks for the suggestion. Meanwhile, I found that
Require LongModuleName.
Module LMN := LongModuleName.
Print LMN.foo.
also works. Is there any reason to prefer the one over the other?
Your way seems better to me:
* shorter to write (not much, but still a gain)
* clearer syntax
* less keywords to memorize (not much, but still a gain)
* I am not sure how memory management is done,
but I guess your way is more efficient as LongModuleName
and LMN should be able to share a common data structure,
while "Include" might require a copy, since you can add
other definitions to the module before closing it, and
thus "modify" the module (so sharing is less evident to be done).
Cheers,
Raghu.
N. Raghavendra <raghu AT hri.res.in>, http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
- [Coq-Club] Qualified imports, N. Raghavendra, 08/09/2015
- <Possible follow-up(s)>
- RE: [Coq-Club] Qualified imports, Soegtrop, Michael, 08/10/2015
- Re: [Coq-Club] Qualified imports, N. Raghavendra, 08/11/2015
- Re: [Coq-Club] Qualified imports, Cedric Auger, 08/11/2015
- RE: [Coq-Club] Qualified imports, Soegtrop, Michael, 08/12/2015
- Re: [Coq-Club] Qualified imports, N. Raghavendra, 08/12/2015
- [Coq-Club] Qualified imports, N. Raghavendra, 08/10/2015
