coq-club - Re: [Coq-Club] Let lifting/unwinding?
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Let lifting/unwinding?
  • Date: Tue, 11 Aug 2015 16:06:53 -0700
Hello, Helge --
Did anyone reply to your question? One way to do this would be to use [fst] instead of pattern matching. You can prove:
Lemma pair_eta : forall {T U} (x : T * U), x = (fst x, snd x).
Proof. destruct x; reflexivity. Defined.
repeat match goal with
       | |- context [ match ?X with (_,_) => _ end ] => rewrite (@pair_eta _ _ X)
       end.
and then phrase your lemmas in terms of [fst], e.g.
forall x, f (fst (baz x)) = g_baz x
Here's an example interaction:
Axiom f : nat -> Prop.
Axiom foo : nat -> nat * nat.
Axiom bar : nat -> nat * nat * nat.
Axiom baz : nat -> nat * nat.
Axiom g_baz : nat -> Prop.
Axiom f_baz : forall x, f (fst (baz x)) = g_baz x.
Goal forall x,
    f (
    let (x', _) := foo x in
    let '(x'', _, _) := bar x' in
    let (x''', _) := baz x'' in
    x''').
Proof.
  intros.
         end.
  rewrite f_baz.
I hope that this helps.
On Mon, Aug 10, 2015 at 1:18 PM, Helge Bahmann <hcb AT chaoticmind.net> wrote:
Hello all,
I have expressions of the kind:
  f (
    let (x'', _, _) := bar x' in
    x''')
which needs to be reduced for a proof, and there are
rules available for performing reduction per each individual
inner operator. There are different ways that I can present these, but
essentially they are all of the kind:
  let (x', _) := baz x in f x' = g_baz (f x)
What I am looking is for ways to automate applications of
these reductions. These need to be performed
"inside out" (first reduce f/baz, then f/bar, then f/foo), but
I always hit a wall trying to formulate the lifting required
in a generalizable fashion.
Does anyone have a trick handy that could apply in a situation
like this? Possibly even automating the case analysis, I already
have trouble with that (given that "foo x"/"bar x"/"baz x" all
have different types and I cannot seem to generalize over that).
Thanks,
Helge
gregory malecha
