- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] representing functions' domains and ranges
- Date: Wed, 19 Aug 2015 10:20:52 +0200
I know of 3 ways to reprensent finite types:
Record fin1 (n:nat) := { v : nat; ranged : v < n }.
Fixpoint fin2 (n:nat) := match n with O => emptySet | S n => option (fin2 n) end.
Inductive fin3 : nat -> Type := X : forall n, fin3 (S n) | Y : forall n, fin3 n -> fin3 (S n).
I often find the second one a good one for low-level stuff.
The third one seems nice, but in fact indice manipulation is really annoying if you do not use a complete enough library to deal with it (I think Coq has some implemented in stdlib).
The first one remains interesting when you have stuff with a lot of arithmetic (in this case, you should forget the other two).
If you do a lot of computationnal things, you may also want to replace the definition of "lt" with something more computationnal, like
Fixpoint lt (m n : nat) : Prop := match n with O => False | S n => match m with O => True | S m => lt m n end end.
Beside that, as Robert wrote you can define:
Record domfun (m n : nat) := DF { df : nat -> nat; dom_spe : forall x, x<m -> (f x) < n }.
This allows you to write things like:
Notation "⟦ f ⟧" := (@df _ _ f).
Notation "« f »" := (@dom_spe _ _ _).
Definition compose (m n o : nat) (f : domfun n o) (g : domfun m n) : domfun m o :=
DF (fun x => ⟦f⟧ (⟦g⟧ x))
(fun x (ltxm:x<m) => «f» («g» ltxm)).
or
Definition compose (m n o : nat) (f : domfun n o) (g : domfun m n) : domfun m o.
refine (DF (fun x => ⟦f⟧ (⟦g⟧ x)) _).
Proof.
Defined. (* And not Qed, as you still want df to be accessible. *)
Or with completely separated definitions (for example in separated files):
Definition compose_fun (m n o : nat) (f : domfun n o) (g : domfun m n) : nat -> nat :=
fun x => ⟦f⟧ (⟦g⟧ x).
Lemma compose_spe (m n o : nat) (f : domfun n o) (g : domfun m n) : forall x, x<m -> compose_fun m n o f g x < o.
Proof. … Qed.
Proof. … Qed.
DF (compose_fun m n o f g) (compose_spe m n o f g).
In all these writings, you have a rather clear separation on computation and proof and you do not play too much with constructors and projectors.
2015-08-18 22:50 GMT+02:00 Vadim Zaliva <vzaliva AT cmu.edu>:
Hi!
I am dealing with proofs which involve class of functions which domain is natural
numbers from 0 to some ’n’ and the range is also natural numbers from 0 to some ‘m’.
Currently I formalized them in Coq as follows:
Definition index_map_spec (domain range: nat) :=
forall n : nat, n < domain -> {v : nat | v < range}.
For example, an identity function would be:
Program Definition identity_index_map
(dr: nat):
index_map_spec dr dr
fun i _ => i.
Are there are other, alternative representations for such functions? My current one works but
proofs look a big messy as expressions end up littered with projection function applications.
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- [Coq-Club] representing functions' domains and ranges, Vadim Zaliva, 08/18/2015
- Re: [Coq-Club] representing functions' domains and ranges, Robbert Krebbers, 08/18/2015
- Re: [Coq-Club] representing functions' domains and ranges, Cedric Auger, 08/19/2015
- Re: [Coq-Club] representing functions' domains and ranges, plastyx, 08/31/2015
