coq-club - RE: [Coq-Club] Nesting MSet in an inductive type
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] Nesting MSet in an inductive type
  • Date: Mon, 24 Aug 2015 09:24:35 +0000
  • Accept-language: de-DE, en-US
Dear Jan,
I have similar issues from time to time. I thought about refactoring parts of
the standard library such that all the basics are done with records and/or
type classes and to use modules only as (sometimes) convenient wrappers
around this. The main advantages of modules over records and type classes are
that they are less strict (as far as I can tell module types are compared by
signature equivalence) and that one can embed tactics and database hints in
modules. The main advantage of records and type calsses is that they can be
used in inductives. I think a collection of a structure definition and proofs
could be done using records and type classes as well. It should also be
possible to keep the flexibility of the module system by making modules which
derive an "implementation record" from an equivalent module. So the idea is
that one can use record / type class based definitions of e.g. a MSet in
inductives and uses modules to create concrete intances of these and to
prepare a convenient environment for automating proofs for such structures.
The main reason I didn't explore this as yet is that I wonder how agreeable
something like this would be in the community. Or put more general: the Coq
standard library looks in some places more evolved than designed and I wonder
how otheres weight compatibility vs. improvement in the design. I would very
much enjoy a discussion on how the Coq library should look like and how we
get there.
Also if someone is interested in working together on exploring such ideas,
please let me know.
Best regards,
Michael
-----Original Message-----
coq-club-request AT inria.fr
[mailto:coq-club-request AT inria.fr]
On Behalf Of Jan Bessai
Sent: Sunday, August 16, 2015 4:45 PM
To:
Subject: Re: [Coq-Club] Nesting MSet in an inductive type
Is there any way to get around the limitation by losing abstraction? It would
probably be ok for me to be restricted e.g. to red-black trees.
Their implementation is backed by Coq.MSets.MSetGenTree and has a concrete
type independent of the order. Unfortunately, to instantiate the
Coq.MSets.MSetGenTree.Ops module OrderedType is required again. I would also
accept duplicating the tree type definition. But then Ops in
Coq.MSets.MSetRBT is a concrete module rather than a module type, so it
cannot include the copied (identical..) definition by inheritance.
Would factoring out tree from MSetGenTree.Ops into a separate module
(type?) and parametrizing MSetRBT and MSetAVL over it be something acceptable
as a pull request for the standard libs?
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Prof. Dr. Hermann Eul
Chairperson of the Supervisory Board: Tiffany Doon Silva
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
