coq-club - Re: [Coq-Club] Problem with Native-Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Problem with Native-Coq
  • Date: Tue, 1 Sep 2015 23:31:06 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 9.mo4.mail-out.ovh.net
  • Ironport-phdr: 9a23:XSkWmh/WaQxtZf9uRHKM819IXTAuvvDOBiVQ1KB91+kcTK2v8tzYMVDF4r011RmSDdmds6oMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47AblHf6ke/8SQVUk2mc1EleqKtQsb7tIee6aObw9XreQJGhT6wM/tZDS6dikHvjPQQmpZoMa0ryxHE8TNicuVSwn50dxrIx06vrvGZp8E4tnwM87J8r48TGZn9Kq8/VPlTCCksG2Ez/szi8xfZHiWV4X5Jd2wGkx9FSyRE6pHhFsP0uyr+nu90yCifMMH7S70vHzq4ufQ4ACT0gTsKYmZquFrcjdZ92f8DrQ==
Hello,
Chantal and I indeed plan to port the PArray library to a branch based
on Coq's trunk, which should solve your problem. This may have to wait
until October, though.
Meanwhile, you can try again with the current native-coq which I've just
updated to improve the communication between Coq and OCaml. Hopefully,
it should solve your problem.
Maxime.
On 08/18/2015 11:25 PM, Christoph-Simon Senjak wrote:
> Hello.
> On 18.08.2015 21:09, Guillaume Melquiond wrote:
>> On 18/08/2015 17:10, Christoph-Simon Senjak wrote:
>>>>> I am trying to use Native-Coq to compile some of my code, and it ...
>>>>> sometimes ... works, and sometimes it doesn't, with no apparent
>>>>> reason.
>>> I cloned from https://github.com/maximedenes/native-coq.git, commit
>>> 7f6f7379b76c9c6240ab8083960a6531efa301c8 (which is the current one).
>> Unless you have a reason to use such an outdated fork, I suggest using
>> Coq itself. The 8.5 branch (and all the 8.5 betas) contains this
>> native_compute mechanism.
> The main reason for using native-coq is that it has the "PArray"
> library, which appears to implement diffarrays. Coq 8.5beta2 does not
> have this library. I could build bindings for diffarrays myself, but I
> preferred them because they were "built in". I really need Arrays,
> IntMaps are too slow. DiffArrays seem to be fast enough in my tests.
> Is something similar in the newer Coq versions? Because I could not
> find it.
> Regards,
> Christoph
  • Re: [Coq-Club] Problem with Native-Coq, Maxime Dénès, 09/01/2015
