coq-club - Re: [Coq-Club] Inductive Records, example needed.
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Inductive Records, example needed.
  • Date: Wed, 9 Sep 2015 21:11:05 +0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ilmars.cirulis AT gmail.com; spf=Pass smtp.mailfrom=ilmars.cirulis AT gmail.com; spf=None smtp.helo=postmaster AT mail-io0-f178.google.com
  • Ironport-phdr: 9a23:PG5SQh1F/Z0Ovm//smDT+DRfVm0co7zxezQtwd8ZsegQLPad9pjvdHbS+e9qxAeQG96Lt7Qd16GP6v+ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC04Lui6vrosKbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBO/xeL19RrhFBhwnNXo07Yvlr1OLGQCI/z4XVngcuhtOGQnMqh/gCMTfqCz/48t53YKAJoXdTKopXTW5p/NqTBrhkjxBPD8j7WXWkeR/iatapFSqoBkpkN2cW52cKPcrJvCVRtgdX2cUBss=
Thank you much! :)
On Mon, Sep 7, 2015 at 2:55 AM, Cedric Auger <sedrikov AT gmail.com> wrote:
2015-09-04 23:09 GMT+02:00 Ilmārs Cīrulis <ilmars.cirulis AT gmail.com>:
Hello,
I tried to make Recursive Records, but I can't find any example. There's no hint in the Coq manual.
The best I could do was "
Inductive R := { head: nat; tail: R }.", but with without a Nil it has no use.
(For example, R -> False is trivial theorem. That means that no instance of this type could possibly exist. :( )
​In inductive context, yes, but there is also the coinductive one.
Otherwise, you can also try:​
Inductive R := { head: nat; tail: option R }.
Or trees:
Inductive R := { index:Type; chidren : index -> R }.
(leaves have index=emptySet)
Thanks in advance,
Ilmars
