coq-club - Re: [Coq-Club] Question about Bishop set (setoid) type theory.
  • From: Guillaume Brunerie <guillaume.brunerie AT gmail.com>
  • To: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Question about Bishop set (setoid) type theory.
  • Date: Wed, 30 Sep 2015 09:52:53 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=guillaume.brunerie AT gmail.com; spf=Pass smtp.mailfrom=guillaume.brunerie AT gmail.com; spf=None smtp.helo=postmaster AT mail-wi0-f169.google.com
  • Ironport-phdr: 9a23:85EiQBNHukabD0BfPNEl6mtUPXoX/o7sNwtQ0KIMzox0KPX7rarrMEGX3/hxlliBBdydsKIYzbeG+Pm6CSQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTrkb3isMSJM01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv+YJa6jxfrw5QLpEF3xmdjltvIy4/SXEGCCI/z43Vngc2jFMHgKNuBr9R9L6tjbwnut7wiiTe8PsG+MaQzOnuoh2SRvsgToCOnYT6nzRh9ZxgeoPrw+goxh23ovZJouPKfxzZKLQVdwfTGtFGM1WUnoSUcuHc4ITAr9Zbq5jpI7nqg5L9EPmCA==
On 2015-09-29 23:39 GMT+02:00 Abhishek Anand
<abhishek.anand.iitg AT gmail.com>
wrote:
>> Is that enough? Are there applications where we do need an
>> approximation function of type R -> Q available inside the type theory
>> or is it enough to be able to compute all approximations of any real
>> number, as long as we are in the empty context?
> In my application, I *need to* approximate reals with free vars (in
> non-empty contexts).
> Consider the function `robotPureProgam` in page 10 of the paper:
> http://www.cs.cornell.edu/~aa755/ROSCoq/ROSCOQ.pdf
> The variable `target` is *not* known in advance and comes from the user of
> the robot at runtime.
> If it helps, here are the slides from a talk about the paper:
> http://www.cs.cornell.edu/~aa755/ROSCoq/ITP.pdf
> Please let me know if I misunderstood the question.
Thanks!
But is there a reason for doing the approximation in this function
instead of even later?
Could you instead have robotPureProgram return something of type list
(R × Polar2D Q), have the `delay' field in `Message` be a real number
instead of a rational number, and then do the approximation only when
sending an actual command to the robot? I guess you can’t send to the
robot a real with free variables,
Best,
Guillaume
> Below, I express some possibly misleading personal opinion:
> The CoRN library[1] has reasonably convinced me that if the "Proper"
> instances for rewriting are declared properly,
> working with unquotiented reals can be a breeze.
> Only a few times I had some minor trouble in rewriting at the denominator of
> division, because the division operator also takes a proof of non-negativity
> of the denominator.
> [1] : http://corn.cs.ru.nl/
>> > Best,
>> > Neel
>> > PS. Andrej Bauer has told me that this is essentially what people
>> > working in Weihrauch's Type Two Effectivity do, but you would need to
>> > ask him for details.
>> > [*] There are technical issues to do with needing negative digits to
>> > implement all the operations (such as addition and multiplications)
>> > using Cauchy sequences, but the solutions are known and so we can
>> > neglect them in this email.
>> > On 25/09/15 22:20, Abhishek Anand wrote:
>> >> I totally agree with Arnaud's point about reals.
>> >> I just want to emphasize the importance of the ability to get rational
>> >> approximations of (constructive) reals.
>> >> I have been using constructive reals for writing certified Coq programs
>> >> for robots [1] and actually running them on actual robots.
>> >> Unlike floating points, at most places I don't have to worry about
>> >> inexactness. For example, field laws hold exactly, and sin^2 x + cos^2
>> >> x
>> >> is /exactly/ equal to 1.
>> >> However, in the end when all the computation is done, and it is time to
>> >> send some commands to hardware, such as timers, or motor drivers, I
>> >> cannot send them constructive reals.
>> >> Instead, I /have to approximate them to a sufficiently simple
>> >> rational/,
>> >> e.g. a timer accepts a millisecond value, and iRobot Create
>> >> <http://www.irobot.com/About-iRobot/STEM/Create-2.aspx> accepts an
>> >> 8-bit
>> >> value representing the requested speed for its motors.
>> >> [1] Abhishek Anand and Ross Knepper. “ROSCoq: Robots powered by
>> >> constructive reals”. In: ITP. Aug.
>> >> 2015. https://github.com/aa755/ROSCoq.
>> >> -- Abhishek
>> >> On Fri, Sep 25, 2015 at 2:19 PM, Arnaud Spiwack
>> >> <aspiwack AT lix.polytechnique.fr
>> >> <mailto:aspiwack AT lix.polytechnique.fr>>
>> >> wrote:
>> >> There is a lot to say about the type theory of setoids. I'll
>> >> attempt
>> >> to share some of my thought on it.
>> >> As Neel said already, OTT is such a theory. It does not have a very
>> >> good story for universes, though, univalence can be seen as a way
>> >> to
>> >> address this particular issue.
>> >> Another difficulty is how to treat quotient types. I don't remember
>> >> very well how they are handled in OTT, though I remember they were
>> >> pretty convincing. Though they can be seen as a generalisation of
>> >> quotients, higher inductive types are really a rather different
>> >> angle on this question (though I may be wrong).
>> >> Setoids serve two purposes: adding some extensionality, and adding
>> >> quotients to the theory of Coq. Both are rather tricky balancing
>> >> games when you want to preserve the computational behaviour of Coq
>> >> (if you don't care about computation, you can just posit
>> >> extensionality and axiomatise quotient types, there are probably
>> >> pitfalls in the case of quotient types, though, has someone looked
>> >> into it?).
>> >> There are two things which I'd consider limits of this approach,
>> >> however. First you would probably need a setoid rewriting thing in
>> >> the tactics nonetheless: it handles more than setoids (like
>> >> ordering) and it is useful for simplification by rewriting (just
>> >> using `repeat rewrite` is terrible for your perfs). The second is
>> >> that there are things which are doubtful when expressed as quotient
>> >> types, like the real numbers: real numbers can be seen as a
>> >> quotient
>> >> of, say, function from the natural numbers to the rational
>> >> (returning an approximation up to 2⁻ⁿ). But if you do so, there is
>> >> no way, in the theory of setoids, to extract an approximation of a
>> >> real, as it's not a function which respects the quotient equality.
>> >> So there are extra complications there (maybe a type a functions
>> >> which are explicitly not equality preserving, but it's not really
>> >> easy to use).
>> >> Of course, there is much unnecessary tedium associated with proofs
>> >> with setoids, and here's to hoping a solution is found some day.
>> >> But
>> >> as you see: it's not easy.
>> >> On 25 September 2015 at 18:52, Gabriel Scherer
>> >> <gabriel.scherer AT gmail.com
>> >> <mailto:gabriel.scherer AT gmail.com>>
>> >> wrote:
>> >> You may be interested in Marc Lasson's paramcoq plugin, which
>> >> generates parametricity witnesses from Coq terms. (So it's not
>> >> trying
>> >> to internalize the fact that terms respect
>> >> equality/parametricity, but
>> >> rather make the meta-theorem available in practice as a
>> >> meta-programming tool.)
>> >> https://github.com/mlasson/paramcoq
>> >> On Fri, Sep 25, 2015 at 4:37 PM, Neelakantan Krishnaswami
>> >> <n.krishnaswami AT cs.bham.ac.uk
>> >> <mailto:n.krishnaswami AT cs.bham.ac.uk>>
>> >> wrote:
>> >> > On 25/09/15 13:35, Ilmārs Cīrulis wrote:
>> >> >> I often have to use Equivalence and Proper (while tinkering
>> >> around),
>> >> >> therefore a question appeared:
>> >> >> What about Coq (or any other proof assistant / type theory)
>> >> where
>> >> >> setoids and morphisms are first class citizens (built in,
>> >> replacing
>> >> >> standard Type and function that becomes something like
>> >> lower
>> >> level of
>> >> >> language). In such case there would be no need of special
>> >> libraries for
>> >> >> Equivalence, Setoid and related libraries for, e.g., lists
>> >> or other data
>> >> >> structures that respects equivalence.
>> >> >> What are cons of such idea?
>> >> > This is essentially the idea behind Observational Type
>> >> Theory; you
>> >> > should look at:
>> >> > * Extensional Equality in Intensional Type Theory. T.
>> >> Altenkirch
>> >> > LICS 1999
>> >> > * Observational equality, now! T. Altenkirch, C. McBride, W.
>> >> Swierstra,
>> >> > PLPV 2007
>> >> > The core idea (every type is a setoid and every definable
>> >> term is a
>> >> > equality-respecting morphism) is very simple, but making all
>> >> the syntax
>> >> > line up to make it work is tricky and intricate.
>> >> > Best,
>> >> > Neel
