coq-club - Re: [Coq-Club] VM/native mode within Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] VM/native mode within Coq
  • Date: Thu, 8 Oct 2015 19:23:32 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=enrico.tassi AT inria.fr; spf=None smtp.mailfrom=gares AT fettunta.org; spf=None smtp.helo=postmaster AT fettunta.org
  • Ironport-phdr: 9a23:jK9jDh+2YwY1uP9uRHKM819IXTAuvvDOBiVQ1KB90OMcTK2v8tzYMVDF4r011RmSDdmdtK8P0rOO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStKU0Jn8jrnqs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCaJ/HoXVS0qmwFTAkCR4RfgX5z29DfzrfF88CicJ8z/C74uD2fxp5x3QQPl3X9UfwUy93va35R9
On Thu, Oct 08, 2015 at 06:37:25PM +0200, Epiphanie wrote:
> > Empirically, based on the rate of discovery of
> > proofs of False, it looks as reliable as the rest of the Coq
> > implementation.
> I am not quite sur I understand that sentence, given there is at least
> two known proof of false in vm_compute (that are still present in the
> current stable release but not the beta, as far as I know), notably one
> using 256 constructor for one object.
AFAIK these bugs have been fixed in the git branch for 8.4. When a new pl
release for 8.4 will be made, the fixes are going to be included.
If you really need a data type with many many constructors and fast
computations on it, just git pull and you'll be good to go.
Best,
Enrico Tassi
