- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] hint cost vs. order
- Date: Thu, 15 Oct 2015 19:10:41 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f179.google.com
- Ironport-phdr: 9a23:ZwJFLR2ejUVNC+TYsmDT+DRfVm0co7zxezQtwd8ZsegeL/ad9pjvdHbS+e9qxAeQG96Lt7QV06GM6OjJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6OyZXvnLrps7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cYk7sb+sVBSaT3ebgjBfwdVWx+cjMDzZa07lybEUPPuyNdAS0qlU9jBBGNxxXnVN+luSzj8+F5xSOyPMvsTLlyVy70vIlxTxq9qiABPiI5+WefrsFxkq9dvFr1pRt5wo3ZZIyYHPV7d6LZO9gdQDwSDY5qSyVdD9bkPMM0BO0bMLMd8tHw
Is it the case that auto is supposed to try all (pattern applicable) hints in ascending cost order, regardless of hint declaration order? That seems to be what the refman implies - although it says very little about cost. However, there appear to be cases where auto will try a higher cost hint that was declared later before a lower cost hint declared earlier. Is that a bug?
Interestingly, it looks like using auto with nocore and a small db can outperform combining the hints from that small db into a single recursive match-based tactic. However, I'm finding it difficult to use hint cost to control the order in which hints are tried.
-- Jonathan
- [Coq-Club] hint cost vs. order, Jonathan Leivent, 10/16/2015
- Re: [Coq-Club] hint cost vs. order, Jason Gross, 10/16/2015
- Re: [Coq-Club] hint cost vs. order, Jonathan Leivent, 10/16/2015
- [Coq-Club] auto performance vs. match (was: hint cost vs. order), Jonathan Leivent, 10/20/2015
