- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Making tactic that return a value
- Date: Wed, 21 Oct 2015 14:46:46 +0200
Hi,
One solution might be to bind the return value to some value in the
environment before returning.
JH
Le 21/10/2015 12:33, Julien Tesson a écrit :
> Hi all !
> I am currently trying to make some tactics that return values, to be used
> by other tactics, but I have some trouble to mix this "functional style"
> with the usual "imperative style".
> I'd like to write tactics that first do some operations on the environment
> and then return a term like this one :
> Ltac test_return :=
> let H := True in
> assert (H=True) by reflexivity;
> constr:H.
> Coq lets me define such Ltac function, but then, when I try to use it, like
> this :
> Ltac mem mem_arg :=
> let H := fresh "Mem" in
> pose (H := mem_arg)
> mem ltac:(test_return).
> I get the error : "Variable mem_arg should be bound to a term". It makes me
> think that no value is returned by the tactic called.
> The only workaround I found was to use a "continuation passing style" like
> this :
> Ltac test_cont cont :=
> let H := True in
> cont constr:H.
> test_return mem.
> But I find this style less convenient to use.
> So here are my questions :
> Is there something that can make test_return work as I expected ?
> If not, I'm curious to know why such kind of thing is not permitted ?
> -- Julien
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Making tactic that return a value, Julien Tesson, 10/21/2015
- Re: [Coq-Club] Making tactic that return a value, Pierre Courtieu, 10/21/2015
- Re: [Coq-Club] Making tactic that return a value, Jacques-Henri Jourdan, 10/21/2015
