Re: [Coq-Club] Why might the reference y not be found in the current environment when it appears in the list of hypotheses?
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Why might the reference y not be found in the current environment when it appears in the list of hypotheses?
- Date: Sun, 25 Oct 2015 15:35:39 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wi0-f170.google.com
- Ironport-phdr: 9a23:tBhABhNgWKRzm91dimwl6mtUPXoX/o7sNwtQ0KIMzox0KPj6rarrMEGX3/hxlliBBdydsKIZzbKO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStOU15z//tvx0qOQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9YwuxhX7vkm7otLVbjwN/AzSqUdBzA7OUg04tfqvF/NV13cyGEbVzAzmwZUAwnI8VnBWYX8uzay4u90xDWTOOXzRKwoUDHk6L1kHky7wBwbPiI0pTmEwvd7i7hW9Uqs
Hi Jason,
It might be that y (and H) are so-called filtered hypotheses here. During unification it was (heuristically) found that the evar/goal couldn't possibly be instantiated by a term mentioning y, typically because the evar was unified with another one which didn't have y in its scope.
Hope this helps,
-- Matthieu
Le dim. 25 oct. 2015 à 03:57, Jason Gross <jasongross9 AT gmail.com> a écrit :
What might be going on here?and get the list:I have the following goal in Coq 8.4pl6 (after Grab Existential Variables; it is left over because I did an [exact_no_check]):I try [exact y], and it fails, telling me that y cannot be found in the current environment. Yet [y] appears. I have done C-c C-p to refresh the goal, and nothing changes. I run the following tactic to list the hypotheses:
2 subgoals, subgoal 1 (ID 15945)
Char : Type
HSL : StringLike Char
HSLP : StringLikeProperties Char
ls : list (string * productions Char)
data : boolean_parser_dataT
constT : Type
varT : Type
strC : str_carrier constT varT
str : String
nt : string
a : nat * nat
x : forall x : nat * nat,
prod_relation lt lt x a ->
nonterminals_listT ->
varT -> forall x2 : nat, x2 <= fst x -> string -> bool
y : forall x0 : nat * nat,
prod_relation lt lt x0 a ->
varT -> forall x3 : nat, x3 <= fst x0 -> string -> bool
H : forall_relation
(fun a' : nat * nat =>
pointwise_relation (prod_relation lt lt a' a)
(forall_relation
(fun _ : nonterminals_listT =>
forall_relation
(fun _ : varT =>
forall_relation
(fun d : nat =>
forall_relation
(fun _ : d <= fst a' =>
forall_relation (fun _ : string => eq))))))) x y
a0 : nonterminals_listT
a1 : varT
a2 : nat
a3 : a2 <= fst a
a4 : string
b : ~ a2 < fst a
a5 : (negb (EqNat.beq_nat (snd a) 0) && is_valid_nonterminal a0 a4)%bool =
true
subgoal 2 (ID 15869) is:
(dependent evars: ?15719 using ?15743 , ?15743 using ?15776 ?15775 ?15774 , ?15774 using ?15964 , ?15775 using , ?15776 using ?15809 ?15808 , ?15808 using ?15834 , ?15809 using ?15885 ?15884 , ?15834 using ?15864 , ?15864 using ?15869 , ?15865 using , ?15869 open, ?15884 using ?15910 , ?15885 using , ?15910 using ?15940 , ?15940 using ?15945 , ?15945 open, ?15964 using ?16010 ?16009 ?16008 ?16007 , ?16007 using , ?16008 using ?16064 ?16063 ?16062 , ?16009 using ?16038 ?16036 , ?16010 using , ?16035 using , ?16036 using ?16048 ?16046 , ?16037 using , ?16038 using , ?16045 using , ?16046 using , ?16047 using , ?16048 using , ?16062 using ?16144 ?16143 , ?16063 using , ?16064 using ?16132 ?16130 , ?16129 using , ?16130 using , ?16131 using , ?16132 using , ?16143 using , ?16144 using ,)
try match goal with
| [ H : _ |- _ ] => idtac H; fail
end.
a5
b
a4
a3
a2
a1
a0
x
a
nt
str
strC
varT
constT
data
ls
HSLP
HSL
Char-Jason
- [Coq-Club] Why might the reference y not be found in the current environment when it appears in the list of hypotheses?, Jason Gross, 10/25/2015
- Re: [Coq-Club] Why might the reference y not be found in the current environment when it appears in the list of hypotheses?, Matthieu Sozeau, 10/25/2015
