coq-club - Re: [Coq-Club] Surprising unification heuristics
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: Beta Ziliani <bziliani AT famaf.unc.edu.ar>, Coq Club <coq-club AT inria.fr>, Matthieu Sozeau <mattam AT mattam.org>
  • Subject: Re: [Coq-Club] Surprising unification heuristics
  • Date: Sun, 1 Nov 2015 11:31:02 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23: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
Hi Beta and Hugo,
Thanks for the explanations; both were very helpful. What mostly surprised me
in the example that I posted is that, while I did expect eauto to be able to
find non-obvious solutions, I did not expect [unify x with true] to behave
differently from [instantiate (1 := true)]. Neither did I expect calling
[reflexivity] on [true = ?1] to produce anything else than [true] for [?1].
Thanks for the explanations!
Clément.
On 11/01/2015 10:25 AM, Beta Ziliani wrote:
> My 2cts:
> Using our algorithm you get the other solution, so effectively the goal is
> [false = true]. (Similarly for the larger program.)
> But, as Hugo said, that is just a heuristic. It works in many cases (like
> yours), but sometimes it fails. What I foresee in a
> hopefully-not-so-far-away future is an algorithm with all the heuristic
> clearly explained in the Reference Manual, with switches to turn on and off
> certain heuristics. There is no way one algorithm will fit everyone's
> expectancies, but at least we can give tools for the interested proof
> developer (e.g., me!).
> Best regards,
> Beta
> On Sat, Oct 31, 2015 at 7:30 PM, Hugo Herbelin
> <Hugo.Herbelin AT inria.fr
> <mailto:Hugo.Herbelin AT inria.fr>>
> wrote:
> Hi Clément,
> I might try to give some comments.
> First, about your f_nil example, there are indeed two say "canonical"
> solutions [a |- ?b:=a] and [a |- ?b:=nil] (*) and Coq heuristically
> chooses the first one, and, in this case, one could indeed consider
> that it should at least not commit to a solution (as a comparison, in
> versions up to 8.2, Coq was doing the other choice!). I don't know
> what Beta and Matthieu's algorithm is doing here.
> (*) Of course, there are also less canonical solutions such as
> e.g. [?b:=match a with nil => nil | _ => cons 0 (cons 0 nil) end], etc.
> Second, I realized that there is a simple way in 8.5 to force the
> choice of the second solution (i.e. nil). Just do
> Unshelve.
> [b]:clear a; shelve.
> before the apply, so as to cut the dependency of ?b into the
> substitution [a:=nil].
> Actually, I even have a patch which allows to directly apply tactics
> on goals of the shelve, where the two lines above (actually working as
> such only when exactly b is on the shelve) can simply be replaced by:
> [b]:clear a.
> However, we are in the process of releasing 8.5beta3 soon and we did
> not decide yet whether this patch shall go in it or if it will go only
> to 8.6.
> Note in passing that the trick is also applicable to Jonathan's issue
> from 10 days ago.
> Third, there is phenomenon in your example which is specific to the
> fact that you are in the constant case nil. If you had f_cons instead
> of f_nil as in
> Definition f (a b: list nat) :=
> match b with
> | nil => False
> | _ => True
> end.
> Lemma f_cons : forall a l, f (cons a l) (cons a l).
> Proof. intros. exact I. Qed.
> Goal forall (a: list nat), exists b, f a b.
> Proof.
> intros.
> eexists.
> induction a as [|n l].
> 2:apply f_cons.
> Then, the second solution above (i.e. [?b:=cons n l] is not anymore a
> solution, because ?b can depend on n and l only via its dependency in
> [a:=cons n l], since n and l are bound below ?b.
> So, what looks to you expected (choosing ?b:=nil in the nil case
> rather than ?b:=a) is actually possible because we are in a degenerate
> case where the constructor has no argument. So, the schema that you're
> expecting does not scale to non-constant constructors.
> In any case, Coq's unification algorithm has been developed
> progressively from case studies and heuristics, starting in the mid
> 90's. In some cases it works as expected (for instance the heuristic
> choosing "a" in the nil case is good for inference of the return
> clause of a "match") and in some cases not, and I'm not able to assert
> that there is a "universal" algorithm and combination of heuristics
> that work always as intuitively expected. This is to me
> research/engineering problem and that's good that people like Beta and
> Matthieu did the effort to start formally writing on paper some of the
> ingredients involved in Coq's unification.
> Hoping it helps.
> Hugo
> On Fri, Oct 30, 2015 at 12:29:21PM -0400, Clément Pit--Claudel wrote:
> > Hi coq-club,
> > I'm slightly puzzled by the behaviour of unification in the following
> script (tested in 8.4pl4 and trunk):
> > Goal forall (a: bool), exists b, a = b.
> > Proof.
> > intros a; eexists.
> > destruct a.
> > (* Two goals: [true = ?6] and [false = ?6] *)
> > apply eq_refl.
> > (* One goal: [false = false] *)
> > Abort.
> > Instead of [false = false], I expected the second goal to become
> [false = true]. Unifying explicitly, instead of applying [eq_refl], yields
> similar results (this example courtesy of my labmate CJ):
> > Proof.
> > intros a; eexists.
> > destruct a.
> > match goal with |- _ = ?x => unify x true end.
> > (* Two goals: [true = true] and [false = false] *)
> > Abort.
> > What seems to happen is that Coq remembers that [a] was destructed
> into [true] in the first branch, and silently replaces [true] by [a] (taken
> from the evar's context) when unifying (thus yielding [false] in the second
> branch). This behaviour is biting me in a larger example, which boils down
> to this:
> > match b with
> > | nil => True
> > | _ => False
> > end.
> > Lemma f_nil : f nil nil.
> > Proof I.
> > Proof.
> > eexists.
> > induction a.
> > apply f_nil.
> > (* Unprovable: the [nil] that comes from applying [f_nil]
> shouldn't have been rewritten to [a] in the inductive case *)
> > Is this considered a bug, or a feature? And is this behaviour still
> present in Beta's and Matthieu's new unification algorithm?
> > Cheers,
> > Clément.
