- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Time analysis
- Date: Mon, 2 Nov 2015 14:04:29 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga03.intel.com
- Ironport-phdr: 9a23:1pYDohKjg972SjOlm9mcpTZWNBhigK39O0sv0rFitYgULf3xwZ3uMQTl6Ol3ixeRBMOAu68C0bed7/+ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0oLtiqvupNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVG679ZuEzSaFSJDUgKWE8osPx/1GXRgyWo3AYT28+kxxSAgGD4gusDbnrtS6v/NF61SaGJ8ruCfgRWD+i5qpvAle8jSYMNzc09CfMjcF/kLhcuDqgoQByx8jfZ4TDZ6k2Rb/UYd5PHTkJZc1WTSEUWo4=
Dear Tillmann,
True. But what you can do, if you are interested in measuring time, is to
call vm_compute with a trivial function, which accepts b and returns a unit.
Then you can subtract this time in your equation and see if both sides get
closer:
Time g a + Time h b - Time "return_unit_from_any_type" b = Time f a
Best regards,
Michael
> -----Original Message-----
> From:
> coq-club-request AT inria.fr
> [mailto:coq-club-request AT inria.fr]
> On
> Behalf Of Tillmann Weisser
> Sent: Monday, November 02, 2015 2:47 PM
> To:
> Dear Michael,
> Indeed, the size of the term b is a problem. However, I have no idea how to
> provide the term b other then by defining Let b:= Eval vm_compute in (g a).
> Best,
> Tillmann
> Am Montag, 02. November 2015 12:13 CET, "Soegtrop, Michael"
> schrieb:
> > Dear Tillmann,
> > I see. Another question is how large the term b is. If it is rather
> > large, the
> marshalling of the term to the VM might take a considerable amount of time.
> Did you try calling an identity function with term b and see how long this
> takes? This should then be subtracted from the run time of h b.
> > Best regards,
> > Michael
> > > Dear Michael,
> > > Here I'm talking about times above 100 seconds and more. For example
> > > Time Eval vm_compute in (f a). (* 119 sec *) Time Eval vm_compute in (g
> a).
> > > (* 39 sec *) Let b:= Eval vm_compute in (g a).
> > > Time Eval vm_compute in (h b). (* 116 sec *)
> > > Best regards,
> > > Tillmann
> > > Am Montag, 02. November 2015 11:36 CET, "Soegtrop, Michael"
> > > schrieb:
> > > > Dear Tillmann,
> > > > did you consider that vm_compute involves some overhead, e.g.
> > > compilation to byte code? In my experience for times above a few
> > > 100ms this is negligible and times add up to about 10%, but for times
> below 100ms not.
> > > About what time scale are we talking in your case?
> > > > Best regards,
> > > > Michael
> > > > Intel Deutschland GmbH
> > > > Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
> > > > Tel: +49 89 99 8853-0, www.intel.de Managing Directors: Christin
> > > > Eisenschmid, Christian Lamprechter Chairperson of the Supervisory
> > > > Board: Nicole Lau Registered Office:
> > > > Munich Commercial Register: Amtsgericht Muenchen HRB 186928
> > Managing Directors: Christin Eisenschmid, Christian Lamprechter
> > Chairperson of the Supervisory Board: Nicole Lau Registered Office:
Registered Office: Munich
- [Coq-Club] Time analysis, Tillmann Weisser, 11/02/2015
- RE: [Coq-Club] Time analysis, Soegtrop, Michael, 11/02/2015
- RE: [Coq-Club] Time analysis, Tillmann Weisser, 11/02/2015
- Re: [Coq-Club] Time analysis, Julien Tesson, 11/02/2015
- Re: [Coq-Club] Time analysis, Cedric Auger, 11/02/2015
