- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A version of "ring" that substitutes equalities
- Date: Thu, 5 Nov 2015 13:27:46 +0100
On 11/04/2015 05:09 PM, Michael Shulman wrote:
I wanted a version of the tactic "ring" which is able to make use of
equalities in the context. So I wrote my own:
Ltac ring_useeq :=
first [ ring
| match goal with
| [ H : ?a = ?b |- _ ] =>
first [ rewrite H; clear H; ring_useeq
| rewrite <- H; clear H; ring_useeq
| clear H; ring_useeq ]
end ].
If I did it right, this is doing a tree search through all possible
combinations of rewriting in either direction or not at all with each
equality in the context. However, one could imagine it being even
smarter and trying more things, e.g. in theory it might matter what
order the rewrites happen in. Does a tactic like this exist already
somewhere?
Mike
As a mattern of fact one can use assumptions with ring if there are of the form A = P where addition and multiplication do not occur in A.
Example 1 :
Require Import ZArith Ring.
Open Scope Z_scope.
Goal forall x y z,
x = y ^ 2 -> (y - z) * (y + z) = x - z^2.
Proof.
intros x y z H; ring [H].
Qed.
You have also grobner like computation available with Loïc Pottier's tactic nsatz. Grobner is a very powerful technique but even for simple example it can be very CPU intensive.
Example 2 from cyclic 3 :
Require Import Reals Nsatz.
Open Scope R_scope.
Goal forall x y z,
x + y + z = 0 ->
x * y + x * z + y * z = 0 ->
x * y * z = 0 -> x * x * x = 0.
Proof.
intros x y z H1 H2 H3; nsatz.
Qed.
There is also a third tactic called nia developed by Frédéric Besson
It just adds some non-linear tricks on top of psatz. In practice I find this tactic very impressive.
Example 3 from bresenham's algo :
Require Import Psatz ZArith.
Open Scope Z_scope.
Goal forall a b c,
0 < a -> Zabs (2 * a * b - 2 * c) <= a -> forall b', Zabs (a * b - c)
<= Zabs (a * b' - c).
Proof.
intros a b c _ H b'.
assert (H1: b = b' \/ Zabs (b - b') >= 1) by nia.
nia.
Qed.
Laurent
- [Coq-Club] A version of "ring" that substitutes equalities, Michael Shulman, 11/04/2015
- Re: [Coq-Club] A version of "ring" that substitutes equalities, Jonathan Leivent, 11/04/2015
- Message not available
- Re: [Coq-Club] A version of "ring" that substitutes equalities, Michael Shulman, 11/04/2015
- Re: [Coq-Club] A version of "ring" that substitutes equalities, Assia Mahboubi, 11/05/2015
- Re: [Coq-Club] A version of "ring" that substitutes equalities, Laurent Thery, 11/05/2015
- Re: [Coq-Club] A version of "ring" that substitutes equalities, Michael Shulman, 11/05/2015
- Re: [Coq-Club] A version of "ring" that substitutes equalities, Dmitrii Pasechnik, 11/05/2015
- Re: [Coq-Club] A version of "ring" that substitutes equalities, Frédéric Besson, 11/05/2015
