coq-club - Re: [Coq-Club] what is firstorder supposed to do?
  • To: Hugo Herbelin <Hugo.Herbelin AT inria.fr>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] what is firstorder supposed to do?
  • Date: Mon, 9 Nov 2015 15:56:49 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f44.google.com
  • Ironport-phdr: 9a23:McJWWhaUvwT4iV8HMf/bFBf/LSx+4OfEezUN459isYplN5qZpM2+bnLW6fgltlLVR4KTs6sC0LqL9fy7EjVbvt6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDvvcGIKFwT23KUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGY2zRakzTKRZATI6KCh1oZSz7ViQBTeIs1sBXWJeshdSCQXB7ReyCrfsvSy8ludn0iSePMveTLYuWD3k4b09DFfDjz5PHDok+imDgctpyalfvRiJphplwoeSbpvDZ9RkeaaIX9QcTHZBV8AZcyFAHI66c8NbDe0HPOVVq4Twj1QLpBq6QwKrAbW8mXdzmnbq0PhigKwaGgbc0VllRopWvQ==
On 11/08/2015 11:23 AM, Hugo Herbelin wrote:
Hi Jonathan,
Indeed, while tauto/intuition are limited to recognizing inductive
types syntactically isomorphic to and/prod, or/sum, False/Empty_set,
True/unit (as well as recognizing not and iff and a few other ad hoc
things such a t=t), firstorder is able to recognize general
propositional-level connectives (in Prop, Set or Type) such as bool or
Inductive and_or (A B C:Prop) :=
| leftpair : A -> B -> and_or A B C
| right : C -> and_or A B C.
as well as general predicate-logic connectives such as
Inductive exists2_2 (A B:Type) (P Q:A->B->Prop) :=
ex_intro2_2 x y : P x y -> Q x y -> exists2_2 A B P Q.
That seems like all non-(mutually-)recursive inductive types - is that correct?
Recognizing nat as a "connective" would have been certainly possible,
but then you would have to recognize other recursive "connectives"
such as, let's say, n-ary conjunction as defined e.g. by
Notation "p .+1" := (S p) (at level 1, left associativity, format "p .+1").
Reserved Notation "∧_{ i < n } P" (at level 80, i ident, P at next level).
Inductive andn (P:nat->Prop) : nat -> Prop :=
| niln : andn P 0
| consn n : P n -> andn P n -> andn P n.+1
where "∧_{ i < n } P" := (andn (fun i => P) n).
and this would require some extra work.
OK.
Note that there exist variants of intuition which recognize general
connectives. The tactic gintuition is recognizing general
(non-recursive, 0-order) mixed-conjunctive/disjunctive connectives in
the style of firstorder. The tactic dintuition is recognizing
(non-recursive, 0-order) purely-conjunctive connectives as well as
similar general purely-disjunctive connectives.
That's good to know.
Is it the case that even though these variants of intuition are not documented, they will be maintained as much as the vanilla intuition tactic?
From a user perspective, this overlapping of similar tactics each of
them with their own specificities is certainly frustrating.
The lack of predictability is frustrating (along with the bugs, of course) to me. It seems like firstorder would (if it were fixed) perform some automated forward chaining - much like that Hint FChain idea I proposed last week, as long as all such hints are posed into the goal as hypotheses. However, deciding whether it would do all forward chaining or not is difficult.
For example, I can come up with goals requiring forward chaining that firstorder solves quite readily, and others that it doesn't. Here's one it doesn't solve:
Goal forall (P : nat -> nat -> Prop),
(forall i j, P i j -> i + j < 2) ->
forall x y z, P x y -> P z y -> y > 0 -> x + z < 1.
Proof.
intros P R x y z Pxy Pyz ygt0.
Fail firstorder omega.
However, an extra level of firstorder does solve it:
firstorder (firstorder omega).
I think I see why, based on debugging the goals that are handed to the tactic arg (omega in this case), but I'm not sure. It looks like each level of firstorder will parameterize the R formula just once - and since omega requires both R x y : x + y < 1 and R x z : x + z < 1, two invocation levels of firstorder are needed. But, I don't know if this is generally the case. Could something like:
Ltac fo n tac := firstorder (tac || lazymatch n with S ?N => fo N tac end).
be used to solve any first-order goal, given sufficiently high n? If not, what are the properties that first-order goals have to have to be solvable this way?
Maybe
could we see it as a sign that we are only at an early stage of the
history of the design of interactive proof methods, automation
procedures and tactic programming languages? Sufficient manpower and
funding to remedy this and to at least understand how to combine the
best of the ideas put in each of the different approaches into
optimally-designed interactive proof methods, automation procedures
and tactic programming languages has apparently not been found yet. I
sense that it may however progressively change... In the meantime, if
anyone on this list feels like he's willing to contribute fair
comparative analyses of the pros and cons of various ideas around,
that can certainly help.
Fair enough. "Help wanted" sign noted...
Back to firstorder, the associated publication is at
"http://www-verimag.imag.fr/~corbinea/ftp/publis/ljti-rr.ps";.
A bit over my head on the first reading...
-- Jonathan
