coq-club - Re: [Coq-Club] deactivating implicit args via tactic
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] deactivating implicit args via tactic
  • Date: Thu, 12 Nov 2015 15:08:55 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f178.google.com
  • Ironport-phdr: 9a23:YVFsZRGgCx9AvmHGUEfcXp1GYnF86YWxBRYc798ds5kLTJ75o82wAkXT6L1XgUPTWs2DsrQf27eQ7/GrADdYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh730p8yYOl4QzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZB0cRlBNUAwHDpDX3X4n8tDey4uh63iiZMMn7QJg7XD2j6+FgTxq+23RPDCIw7GyC0p84t6lcuh/0/xE=
The problem with using an open_constr instead of a uconstr is that all of the implict args immediately become shelved existential goals. Just try doing "Show Existentials" after the head_pose_proof call.
My purpose to trying to get to the explicitized version of the function name is just so I have more control over those shelved existential goals - as in not shelving them. I know I can do a refine (let H:=foo in _) - so that the implicit args become unshelved subgoals, but in this case I want to deal with one arg at a time, and foo might have multiple implicit args.
-- Jonathan
On 11/12/2015 02:48 PM, Jason Gross wrote:
Does this do what you want?
Tactic Notation "with_open" open_constr(v) tactic3(tac) := tac v.
Tactic Notation "foo'" uconstr(v) tactic3(foo2) :=
first [ let v' := constr:v in tryif has_evar v' then fail else pose proof
v
| with_open v foo2 ].
Ltac foo2 v :=
idtac;
match v with
| ?f _ => foo' f foo2
| _ => fail 1
end.
Tactic Notation "head_pose_proof" uconstr(v) := foo' v foo2.
Goal True -> True.
intro H.
head_pose_proof eq_refl.
Or, if you want something simpler:
Ltac head x :=
match x with
| ?f _ => head f
| _ => constr:x
end.
Tactic Notation "head_pose_proof" open_constr(v) := let v' := head v in
pose proof v'.
which may or may not have the behavior you want on things with explicit
arguments already passed.
On Thu, Nov 12, 2015 at 11:35 AM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
Given the name of a function with implicit args, say "foo", the name
"@foo" names the same function with all args made explict. However, the
"@" does not seem to be an operator that one can apply to a name
tactically. For example - the following doesn't work:
Tactic Notation "Explicitly" uconstr(L) := pose proof @L.
as it appears to ignore the "@", with the result that pose proof fails due
to uninferrable implicits.
Is there any way to take a name of a function and tactically change it to
its explicit version?
-- Jonathan
