coq-club - Re: [Coq-Club] Coq 8.5 beta 3
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq 8.5 beta 3
  • Date: Fri, 13 Nov 2015 12:49:59 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 11.mo1.mail-out.ovh.net
  • Ironport-phdr: 9a23:8k/uZB0ESJ60flvKsmDT+DRfVm0co7zxezQtwd8ZsegVL/ad9pjvdHbS+e9qxAeQG96LtrQZ0qGP7ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6PyZnunLnvs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGC6G9noZXy06ExzIGECR6Rj7Wr/0uzv7s+dx1S+XJov4V+ZnCnyZ8653RUqw2288PDkj/TSPhw==
Hello Frédéric,
You can find the opam package for 8.5 beta 3 on the "core-dev" opam repo for coq:
opam repo add coq-core-dev https://coq.inria.fr/opam/core-dev
Beta versions were moved from the "released" repo to "core-dev" because some users found counter-intuitive that opam was suggesting to upgrade stable versions of Coq to betas.
Enjoy!
Maxime.
On 11/12/15 23:41, Frédéric Besson wrote:
Hello Maxime,
Is there an opam package for coq8.5.beta3 — somewhere ?
I have a beta1, beta2 but beta3 does not show up…
Thanks for the good work,
Best,
Frédéric
On 12 Nov 2015, at 01:05, Maxime Dénès
<mail AT maximedenes.fr>
wrote:
Dear Coq-Clubers,
The Coq development team is pleased to announce the release of the
third beta version of Coq 8.5 available at:
http://coq.inria.fr/coq-85
This new beta version includes many bug fixes with respect to the first
two beta versions, and a few incompatible changes, see
the following file for more information:
https://coq.inria.fr/distrib/V8.5beta3/CHANGES
Source, Windows and OS X packages are available.
We recall the new available features of version 8.5:
- asynchronous edition of documents under CoqIDE to keep working on a
proof while Coq checks the other proofs in the background (by Enrico
Tassi);
- universe polymorphism making it possible to reuse the same
definitions at various universe levels (by Matthieu Sozeau);
- primitive projections improving space and time efficiency of
records, and adding eta-conversion for records (by Matthieu Sozeau);
- extensions of the new proof engine featuring dependent subgoals
management, fully backtracking tactics, as well as tactics which can
consider multiple goals together (by Arnaud Spiwack);
- a new reduction procedure called native_compute to evaluate terms
using the OCaml native compiler, for proofs with large computational
steps (by Maxime Dénès).
The main other changes are:
- a new fast compilation chain that skips checking of proofs (producing
.vio files);
- a new construct $(..)$ to call tactics from term definitions;
- a more restrictive guard condition to recover compatibility with axioms
like propositional extensionality and (some consequences of) univalence;
- a new option -type-in-type to collapse the universe hierarchy (makes
the logic inconsistent but useful for exploration);
- a better-behaved alternative to simpl, called cbn;
- various improvements to the tactic language, like a new introduction
pattern [= x1 ... xn] which applies injection on the fly (inspired
by SSReflect); new constructs uconstr:c and type_term c to build
untyped terms in Ltac;
- significant improvements of general efficiency.
See http://coq.inria.fr/ for more details, and the CHANGES file in the
distribution for a comprehensive list.
The Coq development team wishes to acknowledge the many
people who made Coq 8.5 possible: Pierre Boutillier,
Pierre Courtieu, Maxime Dénès, Hugo Herbelin, Pierre Letouzey,
Pierre-Marie Pédrot, Yann Régis-Gianas, Matthieu Sozeau, Arnaud
Spiwack, Enrico Tassi with contributions also from Bruno Barras, Yves
Bertot, Frédéric Besson, Xavier Clerc, Pierre Corbineau,
Jean-Christophe Filliâtre, Julien Forest, Sébastien Hinderer, Assia
Mahboubi, Guillaume Melquiond, Jean-Marc Notin, François Ripault,
Carst Tankink as well as many external contributors.
The Coq Development Team
