coq-club - Re: [Coq-Club] Coq'Art questions (Page 101)
  • From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq'Art questions (Page 101)
  • Date: Fri, 20 Nov 2015 15:24:37 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f41.google.com
  • Ironport-phdr: 9a23:oKCcTB1ds6Qm7swfsmDT+DRfVm0co7zxezQtwd8ZsegTL/ad9pjvdHbS+e9qxAeQG96LtrQa1qGI6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6PyZrqnL7qs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGC6G+nYeGkYRiRtLS1yYs0+mVc+r4yGk5rp2gSLCMZeqROo5CGup4/g1FBHAhyIONjp/+2bS3J8jxJlHqQ6s8kQsi7XfZ5uYYaJz
Hi Yasuaki and welcome,
On 11/20/2015 11:22 AM, Yasuaki Kudo wrote:
> Sorry I meant in my last sentence the second argument *Prop* (not B)
> On Nov 20, 2015, at 19:17, Yasuaki Kudo
> <yasu AT yasuaki.com
> <mailto:yasu AT yasuaki.com>>
> wrote:
>> Hi,
>> I have a question regarding the section of Existential Quantification on
>> Page 101 of /Interactive Theorem Proving and Program Development (Coq’Art)/
>> I hope this is not too nitpicking but because I am self-studying, I want
>> to ensure that I understand the foundation correctly.
>> On Page 78 (4.1.1.6), the book says:
>> /Types for the logical connectives and operator like prod are constructed
>> thanks to the following rule, yet another extension of Prod. The types
>> that are formed in this way are called /higher-order
>> types.
>> /E, G |- A:Type/
>> /E, G |- B:Type/
>> /------------------------------------------ Prod-sup /
>> /E, G |- A->B : Type/
>> On Page 101 (4.3.5.1):
>> /The type of the constant ex has the sort Type; the formation of this type
>> is summarized by the following sequence of judgements (only the third and
>> the forth ones use the rule for building
>> higher-order types):/
>> /[A:Type] |- Prop : Type/
>> /[A:Type] |- A-> Prop : Type/
>> /[A:Type] |- (A -> Prop) -> Prop : Type/
>> /|- //∀A:Type, (A -> Prop) -> Prop : Type/
>> On contrary to the note in parenthesis /(only the third and the forth…)/,
>> it seems that the second example *IS* an example of the formation above
>> where the first argument is *A* and the second being
>> *B*? Am I wrong?
Myself, I see there two utilizations of the Prod-sup rule (for the second and
the third judgements)
and one utilization of Prod(s,s',s'') rule (for the fourth judgment)
Here's the corresponding proof-tree I just sketched
http://matej-kosik.github.io/www/tmp/4.html
(I am not inlining it because I am not sure what MUA would do to it)
(the root is the original goal; children are hypotheses; inner nodes are
intermediate goals; leafs are axioms or trivial judgments)
>> In addition, what does /Prod-sup/ mean? I have seen terms like /dependent
>> *product*/ in the book but I don’t know what product means.
The Prod-sup, like Prod-Set and Prod-Prop is just a special case of
Prod(s,s',s'') rule.
Dependent product is defined here:
https://coq.inria.fr/refman/Reference-Manual003.html#hevea_default22
In other words this:
A → Prop
is a non-dependent product whereas this:
∀ A:Type, (A -> Prop) -> Prop
is a dependept product (because the term "(A -> Prop) -> Prop" contains "A"
as a free variable).
Hope this helps,
Regards,
m
