- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Existential instantiation with addition information
- Date: Thu, 26 Nov 2015 23:36:39 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=arnaud.spiwack AT gmail.com; spf=Pass smtp.mailfrom=arnaud.spiwack AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f49.google.com
- Ironport-phdr: 9a23:RuxUOxFk557zjAQ+KwCOVZ1GYnF86YWxBRYc798ds5kLTJ75r8ywAkXT6L1XgUPTWs2DsrQf27eQ4/mrATFIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niqbiotaLPk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv+YJa6jxfrw5QLpEF3xmdjltvIy4/SXEGCCI/zM3Vngc2k5DBBGA5xXnVL/wtDH7v6xzwn/JE9fxSOUdQzKr8qsjcwfply4MNHZt+XrPi9N5h6FzpBOx4QR4x5/IbYqVMvtnY66bc8lMFjkJZdpYSyEUWtD0VIAIFedUeL8A94Q=
I don't think that this is intuitionistically provable when P is not
decidable though.
Let A be a proposition and P n be the statement that { x:unit | A } has at most n elements. Clearly P 1 holds. However, if P has a minimal witness, then by case analyses on that minimal witness we can decide whether A\/~A.
Now, on the other hand, `forall n,
P n -> exists m, P m /\ (forall p, p < m -> ~ P p)` doesn't implies that `P` is decidable. Take a function s:nat -> bool, and consider `P n` to be the proposition that `exists k>n, s k = true`. P is not decidable (this is Bishop's limited principle of omniscience), however, clearly if `P n` then there exists a minimal such n (namely 0).
- [Coq-Club] Existential instantiation with addition information, David Asher, 11/26/2015
- Re: [Coq-Club] Existential instantiation with addition information, Adam Chlipala, 11/26/2015
- Re: [Coq-Club] Existential instantiation with addition information, Pierre-Marie Pédrot, 11/26/2015
- Re: [Coq-Club] Existential instantiation with addition information, Dominique Larchey-Wendling, 11/26/2015
- Re: [Coq-Club] Existential instantiation with addition information, Xavier Leroy, 11/26/2015
- Re: [Coq-Club] Existential instantiation with addition information, Jean-Francois Monin, 11/26/2015
- Re: [Coq-Club] Existential instantiation with addition information, Arnaud Spiwack, 11/26/2015
- Re: [Coq-Club] Existential instantiation with addition information, Arnaud Spiwack, 11/28/2015
