- To: coq-club AT inria.fr
- Subject: [Coq-Club] Well founded induction on Zwf
- Date: Sun, 29 Nov 2015 04:06:48 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=ncyms8r3x2 AT snkmail.com; spf=None smtp.mailfrom=ncyms8r3x2 AT snkmail.com; spf=None smtp.helo=postmaster AT sneak2.sneakemail.com
- Ironport-phdr: 9a23:+Ula6hf8AGFSbV9nR3t0ZrYAlGMj4u6mDksu8pMizoh2WeGdxc65bR7h7PlgxGXEQZ/co6odzbGG7uawBydbu96oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDvvc2NKF4SzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZBy81gx5FSzPZ4RT3WN255i3xp+9miDPBLZfeVrY3XD2j6+FgTxq+23RPDCIw7GyC0p84t6lcuh/0/xE=
I wrote a factorial function that uses well founded induction on Z:
However, I can't evaluate calls to the function because Zwf_well_founded is opaque.Require Import ZArith.
Require Import ZArith.Zwf.
Require Import Program.Wf.
Open Scope Z.
Program Fixpoint fact (x:Z) {wf (Zwf 1) x} : Z :=
(match Z_lt_le_dec x 1 with
| left _ => 0
| right _ =>
match x with
| 1 => 1
| _ => x * fact (x - 1)
end
end).
Solve Obligations using (
intros;
try split;
try omega;
try discriminate).
Open Scope Z.
| left _ => 0
| right _ =>
match x with
| 1 => 1
end
end).
intros;
try split;
try omega;
try discriminate).
Eval compute in (fact 3).
= (fix Fix_F_sub (x : Z)
(r : Acc
(fun x0 y : Z =>
(match y with
end) 3 (Zwf_well_founded 1 3) 3 eq_refl)
: Z
(r : Acc
(fun x0 y : Z =>
(match y with
: Z
Since I know the depth of Zwf_well_founded's proof tree, I can work around the problem by creating a transparent well founded induction theorem that just unrolls the original theorem's proof tree.
Is there a cleaner solution? Ideally I'd like to prove that Coq can fully evaluate the function for any parameters, but I'm not sure if that's possible.
Theorem Zwf_well_founded' : forall c, well_founded (Zwf c).
Proof.
intros c x.
pose (n:=Z.to_nat (x - c)).
generalize x.
induction n.
- constructor.
constructor.
apply Zwf_well_founded.
- constructor.
constructor.
apply IHn.
Defined.
Local Obligation Tactic := idtac.
Program Fixpoint fact' (x:Z) {wf (Zwf 1) x} : Z :=
| left _ => 0
| right _ =>
match x with
| 1 => 1
| _ => x * fact' (x - 1)
end
end).
intros;
try split;
try omega;
try apply Zwf_well_founded';
try discriminate).
Eval compute in (fact' 3).
= 6
: Z
Proof.
intros c x.
generalize x.
induction n.
- constructor.
constructor.
- constructor.
constructor.
apply IHn.
Defined.
| left _ => 0
| right _ =>
match x with
| 1 => 1
end
end).
intros;
try split;
try omega;
try discriminate).
= 6
: Z
- [Coq-Club] Well founded induction on Zwf, Kyle Stemen, 11/29/2015
- Re: [Coq-Club] Well founded induction on Zwf, Laurent Thery, 11/29/2015
