coq-club - [Coq-Club] dealing with setoid rewriting problems
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] dealing with setoid rewriting problems
  • Date: Mon, 30 Nov 2015 15:50:07 -0800
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vadim.zaliva AT west.cmu.edu; spf=None smtp.mailfrom=vadim.zaliva AT west.cmu.edu; spf=None smtp.helo=postmaster AT mail-pa0-f42.google.com
  • Ironport-phdr: 9a23:DTdKsBWcqQiCWxEmzuVd20HXjZ/V8LGtZVwlr6E/grcLSJyIuqrYZheGt8tkgFKBZ4jH8fUM07OQ6PC9HzxRqs/f+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8CVM1QD3WT1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDrBNEAg2N3hj+X4n4+n/kpON52TeTFcbzUPY5VSn0vPQjcwPhlCpSb21xy2rQkMEl1K8=
I am using 8.4pl6 and get into the situation where using ’setoid_rewrite’ or
’setoid_replace’ tactics
just hangs up there and does not terminate. Any advice on how this problem
could be debugged?
Can I enable some trace to see what it is doing? I tried to extract a small
example demonstrating
the problem but failed as my proofs depend on a couple of 3rd party libraries.
A related question: I wan to try this under Coq 8.5. Somebody posted once a
link to web page
which shows status of some automated build check showing what libraries are
compatible with
different coq versions. I could not find it. In particular I need both
“CoLoR” and “math-classes”
to be able to try my proof under 8.5.
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
