[Coq-Club] Error: The reference Equivalence was not found in the current environment.
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Error: The reference Equivalence was not found in the current environment.
- Date: Fri, 11 Dec 2015 01:14:56 +0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tesleft AT hotmail.com; spf=Pass smtp.mailfrom=tesleft AT hotmail.com; spf=None smtp.helo=postmaster AT BAY004-OMC1S11.hotmail.com
- Importance: Normal
- Ironport-phdr: 9a23:1OLYaRCSdUgUhN1XPW1pUyQJP3N1i/DPJgcQr6AfoPdwSP7+r8bcNUDSrc9gkEXOFd2CrakU1ayP7OuxAiQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTpkbntsMyIKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvCwdKMhCLdcET4OMmYv5cStuwOJBV+E4WJZWWELmDJJBRLE5Vf0RMGinDH9s79Y0S+WLIXTRKooWDKlp/N3RQTshSkbHz4+7GTei8g2h6Ve9kHy7ydjypLZNdnGfMF1ebnQKIsX
Hi,
after using code in geo coq github
where is equivalence ?
Add LoadPath "C:\Users\tester\Downloads\GeoCoq-1.0.1".
Add LoadPath "C:\Program Files\Coq\lib".
Class Hilbert := {
Point : Type;
Line : Type;
EqL : Line -> Line -> Prop;
EqL_Equiv : Equivalence EqL; <---------------------------------------Error at here
Incid : Point -> Line -> Prop;
(** Group I Incidence *)
line_existence : forall A B, A<>B -> exists l, Incid A l /\ Incid B l;
line_unicity : forall A B l m, A <> B -> Incid A l -> Incid B l -> Incid A m -> Incid B m -> EqL l m;
two_points_on_line : forall l, exists A, exists B, Incid B l /\ Incid A l /\ A <> B;
ColH := fun A B C => exists l, Incid A l /\ Incid B l /\ Incid C l;
plan : exists A, exists B, exists C, ~ ColH A B C;
(** Group II Order *)
BetH : Point -> Point -> Point -> Prop;
between_col : forall A B C : Point, BetH A B C -> ColH A B C;
between_comm : forall A B C : Point, BetH A B C -> BetH C B A;
between_out : forall A B : Point, A <> B -> exists C : Point, BetH A B C;
between_only_one : forall A B C : Point, BetH A B C -> ~ BetH B C A /\ ~ BetH B A C;
between_one : forall A B C, A<>B -> A<>C -> B<>C -> ColH A B C -> BetH A B C \/ BetH B C A \/ BetH B A C;
cut := fun l A B => ~ Incid A l /\ ~ Incid B l /\ exists I, Incid I l /\ BetH A I B;
pasch : forall A B C l, ~ ColH A B C -> ~ Incid C l -> cut l A B -> cut l A C \/ cut l B C;
(** Group III Parallels *)
Para := fun l m => ~ exists X, Incid X l /\ Incid X m;
euclid_existence : forall l P, ~ Incid P l -> exists m, Para l m;
euclid_unicity : forall l P m1 m2, ~ Incid P l -> Para l m1 -> Incid P m1-> Para l m2 -> Incid P m2 -> EqL m1 m2;
(** Group IV Congruence *)
CongH : Point -> Point -> Point -> Point -> Prop;
cong_pseudo_transitivity : forall A B C D E F, CongH A B C D -> CongH A B E F -> CongH C D E F;
cong_refl : forall A B, CongH A B A B;
cong_existence : forall A B l M, A <> B -> Incid M l -> exists A', exists B',
Incid A' l /\ Incid B' l /\ BetH A' M B' /\ CongH M A' A B /\ CongH M B' A B;
cong_unicity : forall A B l M A' B' A'' B'', A <> B -> Incid M l ->
Incid A' l -> Incid B' l ->
Incid A'' l -> Incid B'' l ->
BetH A' M B' -> CongH M A' A B ->
CongH M B' A B -> BetH A'' M B'' ->
CongH M A'' A B ->
CongH M B'' A B ->
(A' = A'' /\ B' = B'') \/ (A' = B'' /\ B' = A'');
disjoint := fun A B C D => ~ exists P, BetH A P B /\ BetH C P D;
addition: forall A B C A' B' C', ColH A B C -> ColH A' B' C' ->
disjoint A B B C -> disjoint A' B' B' C' ->
CongH A B A' B' -> CongH B C B' C' -> CongH A C A' C';
Angle := @Triple Point;
angle := build_triple Point;
CongaH : Angle -> Angle -> Prop;
cong_5 : forall A B C A' B' C', forall H1 : (B<>A /\ C<>A), forall H2: B' <> A' /\ C' <> A',
forall H3 : (A<>B /\ C<>B), forall H4: A' <> B' /\ C' <> B',
CongH A B A' B' -> CongH A C A' C' -> CongaH (angle B A C H1) (angle B' A' C' H2) ->
CongaH (angle A B C H3) (angle A' B' C' H4);
same_side := fun A B l => exists P, cut l A P /\ cut l B P;
outH := fun P A B => BetH P A B \/ BetH P B A \/ (P <> A /\ A = B);
InAngleH := fun a P =>
(exists M, BetH (V1 a) M (V2 a) /\ ((outH (V a) M P) \/ M = (V a))) \/
outH (V a) (V1 a) P \/ outH (V a) (V2 a) P;
Hline := @Couple Point;
line_of_hline : Hline -> Line;
hline_construction := fun a (h: Hline) P (hc:Hline) H =>
(P1 h) = (P1 hc) /\
CongaH a (angle (P2 h) (P1 h) (P2 hc) (conj (sym_not_equal (Cond h)) H)) /\
(forall M, InAngleH (angle (P2 h) (P1 h) (P2 hc) (conj (sym_not_equal (Cond h)) H)) M ->
same_side P M (line_of_hline h));
aux : forall (h h1 : Hline), P1 h = P1 h1 -> P2 h1 <> P1 h;
hcong_4_existence: forall a h P,
~Incid P (line_of_hline h) -> ~ BetH (V1 a)(V a)(V2 a) ->
exists h1, (P1 h) = (P1 h1) /\ (forall CondAux : P1 h = P1 h1,
CongaH a (angle (P2 h) (P1 h) (P2 h1) (conj (sym_not_equal (Cond h)) (aux h h1 CondAux)))
/\ (forall M, ~ Incid M (line_of_hline h) /\ InAngleH (angle (P2 h) (P1 h) (P2 h1) (conj (sym_not_equal (Cond h)) (aux h h1 CondAux))) M
-> same_side P M (line_of_hline h)));
hEq : relation Hline := fun h1 h2 => (P1 h1) = (P1 h2) /\
((P2 h1) = (P2 h2) \/ BetH (P1 h1) (P2 h2) (P2 h1) \/
BetH (P1 h1) (P2 h1) (P2 h2));
hcong_4_unicity :
forall a h P h1 h2 HH1 HH2,
hline_construction a h P h1 HH1 -> hline_construction a h P h2 HH2 ->
hEq h1 h2
Regards,
Martin
- [Coq-Club] Error: The reference Equivalence was not found in the current environment., Mandy Martino, 12/10/2015
