RE: [Coq-Club] is there an example about data mining new geometry theorems with geo coq github and translate proof into a polynomials system
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] is there an example about data mining new geometry theorems with geo coq github and translate proof into a polynomials system
- Date: Mon, 14 Dec 2015 19:39:13 +0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tesleft AT hotmail.com; spf=Pass smtp.mailfrom=tesleft AT hotmail.com; spf=None smtp.helo=postmaster AT BAY004-OMC1S25.hotmail.com
- Importance: Normal
- Ironport-phdr: 9a23:RR4IcxFV6VMyVW6pHBLHQp1GYnF86YWxBRYc798ds5kLTJ75osSwAkXT6L1XgUPTWs2DsrQf27SQ6f2rAz1IyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niaboptaJMk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvNa8/VPlTCCksG2Ez/szi8xfZB0Pb7XwFF24SjxBgAg7f7Ri8UI2n4QXgse8o/SCcMdy+aLkuRTWk6O8/VBLzjCoJKxY5933Sg810yqlcpUTy9FRE34fIbdTNZ7JFdaTHcIZCSA==
Hi ,
i can not search setoid_rewrite function's implementation
https://github.com/GeoCoq/GeoCoq/search?utf8=%E2%9C%93&q=setoid_rewrite
if i would like to change setoid 's transitive to another definition, which file can i edit to change it?
if i edit the file, does it mean that make clean in geocoq directory and make and make install again then it can apply the new definition?
Date: Mon, 14 Dec 2015 04:24:04 +0000
To: coq-club AT inria.fr; coq-club AT inria.fr
Subject: Re: [Coq-Club] is there an example about data mining new geometry theorems with geo coq github and translate proof into a polynomials system
Regards,
Martin
For question 3, I discover Isabelle's lemma proof result can be translated to function body in f# or Haskell these type language such as reverse function.
So, I guess whether there are tools to do these translate in coq so that it can generate all possible functions based on lemma for type language, no need to discover manually.
Hi,
Thanks you for your interest in GeoCoq.
2015-12-08 11:11 GMT+01:00 Mandy Martino
<tesleft AT hotmail.com>:
Hi,
1.would like to data mining new geometry theorems with geo coq github's coq scriptis there an example script about this?
Currently there is no such script in GeoCoq. I only have some maple scripts to find properties of triangle centers and generate Coq scripts (https://hal.inria.fr/hal-01174131 ).
2. is there an example to translate proof into a polynomials system ?
There is an early prototype tactic "convert_to_algebra", with an example using the Euler circle at the end of this file:
This tactic use the proofs of the algebraic characterizations of geometric predicates to convert a geometric statement into an algebraic one. For the moment the following predicates are supported: length equality, midpoint, collinearity,
perpendicularity parallelism equality of points.
3. would like to translate tactics proof result into type programming language, is there example about this?
I don't understand what you mean. Can you please tell me a bit more ?
4.is there any existing language can call Coq or automate Coq ? can haskell or F# or java do these?
There is the tactic language of Coq called Ltac.
5. how can display geometric graph with geogebra from Coq in linux and window respectively?
There is no automated tool for that. In the past there were GeoView by Bertot, Guilhot and Pottier (https://www-sop.inria.fr/lemme/geoview/geoview.ps) but this tool is no longer maintained.
Regards,
Julien Narboux
- [Coq-Club] is there an example about data mining new geometry theorems with geo coq github and translate proof into a polynomials system, Mandy Martino, 12/08/2015
- Re: [Coq-Club] is there an example about data mining new geometry theorems with geo coq github and translate proof into a polynomials system, Julien Narboux, 12/12/2015
- Re: [Coq-Club] is there an example about data mining new geometry theorems with geo coq github and translate proof into a polynomials system, Martin Mandy, 12/14/2015
- RE: [Coq-Club] is there an example about data mining new geometry theorems with geo coq github and translate proof into a polynomials system, Mandy Martino, 12/14/2015
