- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Add Load Path however still can not find library
- Date: Sun, 20 Dec 2015 11:42:12 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f182.google.com
- Ironport-phdr: 9a23:xVIs4hTsJsBkfNl6O/xzfG9Ql9psv+yvbD5Q0YIujvd0So/mwa64YRaN2/xhgRfzUJnB7Loc0qyN4/6mATRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niabqo9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULYQWD8hKiU+4NDhnRjFVwqGoHUGBDY4iB1NViHP7BDhXpry+gL8v+xxkH2TN833VrA5WnKr6a5tRFnpiTsIHzE8+WDTzMd3ifQI81qauxVjztuMM8muP/1kc/aFcA==
The answer is clearly described in the description of the commands "Add Loadpath" and "Require Import" in the manual at
To summarize, you must ensure that the file
/home/martin/hilbertreborn/GeoCoq/Tarski_dev/Annexes/midpoint_theorems.vo
exists. Perhaps you haven't compiled the library GeoCoq.
Also, I would highly recommend first reading some basic Coq tutorial.
Perhaps read the first few chapters of
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Sun, Dec 20, 2015 at 1:55 AM, Mandy Martino <tesleft AT hotmail.com> wrote:
Hi,martin@ubuntu:~/hilbertreborn/GeoCoq/Highschool$ coqtopWelcome to Coq 8.4pl6 (December 2015)Coq < Add LoadPath "/home/martin/hilbertreborn/GeoCoq/".Require Import GeoCoq.Tarski_dev.Annexes.midpoint_theorems.Coq <Error: Cannot find library GeoCoq.Tarski_dev.Annexes.midpoint_theorems in loadpathRegards,Martin
- [Coq-Club] make error for geocoq, Mandy Martino, 12/11/2015
- Re: [Coq-Club] make error for geocoq, Julien Narboux, 12/12/2015
- [Coq-Club] Add Load Path however still can not find library, Mandy Martino, 12/20/2015
- Re: [Coq-Club] Add Load Path however still can not find library, Abhishek Anand, 12/20/2015
