coq-club - Re: [Coq-Club] Proper morphisms for family of functions
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Proper morphisms for family of functions
  • Date: Tue, 29 Dec 2015 22:05:23 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f179.google.com
  • Ironport-phdr: 9a23:HHeQshwsHVgbDqDXCy+O+j09IxM/srCxBDY+r6Qd0e8UIJqq85mqBkHD//Il1AaPBtWFraocw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2WVTerzWI4CIIHV2nbEwudrqzQtaapv/0/t7x0qWbWx9Piju5bOE6BzSNhiKViPMrh5B/IL060BrDrygAUe1XwWR1OQDbxE6ktY/jtKJkpi9Xorcq89NKGfHxeL19RrhFBhwnNXo07Yvlr0+QYxGI4y41WGUXiRpFAEDs6hj8Ut+luyH6t/F91SrcNMv/S7xyWDW+4I9kTRbpjGEMMDtvozKfsdB5kK8O+EHpnBd42YOBOIw=
I typically combine the dependent arguments with their indices, and pick an appropriate equality for the combination.
In your case, I would redefine my `f` so that it has the following type:
f: {i | i<n} -> A -> A
Then I would declare the equality Instance for  {i | i<n}  to be the equality of the corresponding first projections.
Then I would prove an instance of the form
Proper (equal  ==> equal  ==> equal ) f.
Below is a complete example using MathClasses:
Require Import MathClasses.interfaces.canonical_names.
Require Import MathClasses.theory.setoids.
Require Import MathClasses.implementations.peano_naturals.
Section rewriteTest.
Variable A:Type.
Variable  n:nat.
Variable f: {i | (i<n)%nat} -> A -> A.
Global Instance Equiv1 : Equiv {i | (i<n)%nat} := sig_equiv _.
Context `{equal : Equiv A} `{Equivalence A equal}.
Global Instance ProperF :
Proper (equiv ==> equiv ==> equiv) f.
Admitted.
Lemma rewriteTest : forall i1 i2 p1 p2 a1 a2,
i1=i2
-> a1=a2
-> f (i1 ↾ p1) a1 = f  (i2 ↾ p2) a2.
Proof using All.
  intros ? ? ? ? ? ? H1 H2.
  change ((i1 ↾ p1) = (i2 ↾ p2)) in H1.
  rewrite H2.
  rewrite H1.
  reflexivity.
Qed.
End rewriteTest.
On Tue, Dec 29, 2015 at 6:36 PM, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
I have a family of functions defined like this:
f: forall i, i<n -> A -> A
where {A:Type} and {n:nat}. Now I need to specify that for all ‘i’
A->A are proper wrt. my custom equality (equal). In other words
for all ‘i’ following holds:
`{pF: !Proper ((equal) ==> (equal)) f}
What is the best way to specify this, so I can make use of it in
setoid rewriting?
Thanks!
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
