- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] ring_simplify blowup
- Date: Mon, 4 Jan 2016 17:23:09 +0100
On 01/01/2016 01:39 AM, Abhishek Anand wrote:
Recently, I have often encountered situations where ring_simplify would
never return and take up all the memory (~16GB).
In these cases, the involved ring (say Rslow) is a computational one,
i.e. the ring operations have concrete implementations in Coq, and are
not axiomatic.
When ask ring_simplify to simplify the exact same formula in a different
ring, e.g. Z, or a totally abstract one, ring_simplify immediately
returns with the correct answer (normal form).
Once I obtain the normal form, I can go back to the original ring Rslow,
and quickly
prove the correctness of the normal form using the ring tactic.
Did you solve your problem? My guess is that you get stuck because of some hidden computation in Rslow.
In your example in Rslow you want to simplify A into B.
What happens if you do directly
Goal A = B.
ring.
Is this immediate?
What about
Goal B = 0.
ring_simplify
does this get stuck too?
regards,
Laurent
- [Coq-Club] ring_simplify blowup, Abhishek Anand, 01/01/2016
- Re: [Coq-Club] ring_simplify blowup, Laurent Thery, 01/04/2016
- Re: [Coq-Club] ring_simplify blowup, Abhishek Anand, 01/05/2016
