coq-club - Re: [Coq-Club] rewrite_strat Question
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] rewrite_strat Question
  • Date: Thu, 7 Jan 2016 13:08:25 -0800
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gmalecha AT gmail.com; spf=Pass smtp.mailfrom=gmalecha AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f177.google.com
  • Ironport-phdr: 9a23:pvGZSxWkaWOjg5wZRz7MOJw3rLfV8LGtZVwlr6E/grcLSJyIuqrYZhKDt8tkgFKBZ4jH8fUM07OQ6PC+HzRYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh770o8WbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6LoJvvRNWqTifqk+UacQTHF/azh0t4XXskzoShLHzX8BWC1CmR1RRgPB8RvSX5HrsyK8uPAriweAOsijYqo5VjO4/u9OQRvlgycOf2o29WjTh8dwhYpUpRugo1p0xIuCM9LdD+Z3Yq6IJYBSfmFGRMsEEnUZWo4=
I figured out the problem. I was missing an [eval cbv beta] to reduce the term. This works:
rewrite_strat (bottomup (hints pulling ; eval cbv beta)).
I'm a little surprised that I don't need to do another pass.
On Thu, Jan 7, 2016 at 12:50 PM, Gregory Malecha <gmalecha AT gmail.com> wrote:
Hello --
I'm trying to benchmark rewrite_strat and I'm having trouble constructing a strategy that lifts all existential quantifiers over conjunctions. Here are the two lemmas that I'm using:
Theorem pull_ex_and_left
: forall T P Q, Basics.flip Basics.impl ((@ex T P) /\ Q) (exists n, P n /\ Q).
Admitted.
Theorem pull_ex_and_right
: forall T P Q, Basics.flip Basics.impl (Q /\ (@ex T P)) (exists n, Q /\ P n).
Admitted.
Hint Rewrite pull_ex_and_left : pulling.
Hint Rewrite pull_ex_and_right : pulling.
Here is a simple goal that I've been using for testing:
Goal ((((exists _ : nat, 0 = 0) /\ (exists _ : nat, 0 = 0)) /\
   (((exists _ : nat, 0 = 0) /\ (exists _ : nat, 0 = 0)) /\ 0 = 0 /\ 0 = 0) /\
   (0 = 0 /\ 0 = 0) /\ 0 = 0 /\ 0 = 0.
My idea for the procedure was lift existentials bottom up. When you hit a conjunction, pull all the exisentials out of each side. This seems to require top-down rewriting so I tried:
rewrite_strat (bottomup (repeat (topdown (hints pulling)))).
but this is not able to pull all of the quantifiers in one invocation. Is there something that I am missing about how rewrite_strat works? Or am I just making a foolish mistake.
Thanks so much.
gregory malecha
gregory malecha
