- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] specialize a subset of the parameters of a hypothesis
- Date: Sat, 9 Jan 2016 12:22:20 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f179.google.com
- Ironport-phdr: 9a23:R2ZsYxZq80aZF0tht5lHteT/LSx+4OfEezUN459isYplN5qZpcq8bnLW6fgltlLVR4KTs6sC0LqI9fi4EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35rxj7j60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGx48sgs/M9YUKj8Y79wDfkBVGxnYCgJ45jAsgCLZg+S7DNIWWIP1xFMHgLt7RfgX563vDGs5cRn3yzPH8rwRKw0UDLqy6pqVhLulG9TNTk/8WLajsF9pK1eqROl4Rd4xtiHM8muKPNic/aFLpshTm1bU5MUDnQZDw==
Attached. Example usage at the end of abstractedas.v. I haven't tested any other cases - so caveats apply. Let me know if it needs fixing.
The one undocumented v8.5 feature it uses is named evars in numbergoals.v (?[__Number_Goals]) - but this can be removed in the case of the abstracted as tactic if necessary (by using an evar created in abstracted as prior to the "unshelve tac" call).
-- Jonathan
On 01/08/2016 07:14 PM, Pierre Courtieu wrote:
That would be very nice. Thanks Jonathan!
Pierre
Le vendredi 8 janvier 2016, Jonathan Leivent
<jonikelee AT gmail.com>
a écrit :
On 01/08/2016 01:03 PM, Pierre Courtieu wrote:
Thanks for the answers. This is also the solution I came up with, moreI think I can do this entirely in Ltac in v8.5 (but not v8.4). Briefly, it
or less. But what one really want is to use the unification stuff
during the process, so that instantiating one argument also
instantiates some other (prvious) arguments.
Suppose you have
H0: Q a b c
H: forall x t y z, P x t -> Q x y z -> R.
Then "specialize with (2:=H0)" should actually instantiate x y and z:
H0: Q a b c
H: forall t, P a t -> R.
P.
would start off with something like this:
Goal forall a b c, Q a b c ->
(forall x t y z, P x t -> Q x y z -> R) -> False.
Proof.
intros a b c H0 H.
evar (T:Type).
let p := constr:(ltac:(
intro Admit;
subst T;
unshelve eapply H with (2:=H0);
apply Admit): (forall T, T) -> T) in
idtac p.
but would also use a goal numbering tactic I wrote to first number each of
the subgoals generated by the eapply, then incorporate that number into the
Admit so that the resulting subterm generated for each subgoal has
something like a De Bruijn index in it. Then parse that result with
match/context replacement to change each of those Admit subterms into a
variable bound in an outer fun.
I'll give it a try if you don't mind the fact that the result will contain
a lot of Ltac hacking. Also, unfortunately, because there is no Tactic
Notation arg type for passing a "constr_with_bindings_arg_list" down to
that eapply, you'd have to pass the eapply in as a tactic - so the
top-level invocation would have to look at least something like:
foo eapply H with (2:=H0)
But, it would be a general solution in as much as eapply is itself a
general solution: any number of correct bindings would be allowed.
-- Jonathan
(*********************************************************************** Tag each goal in focus with its number and the number of focused goals. ***********************************************************************) (*Type for the tag hypothesis*) Inductive goalNumber(n ofN : nat) : Prop := GoalNumber. Ltac number_goals := [> tryif is_evar ?__Number_Goals then fail "number_goals: The evar name ?__Number_Goals is being used" else idtac | ..]; (*Clear any previous goal number tags*) [> repeat match goal with H : goalNumber _ _ |- _ => clear H end..]; [> assert True as _; [ clear; refine (let _ := ?[__Number_Goals] : nat in _) |] | ..]; [> | pose (?__Number_Goals) ..]; [> | lazymatch goal with NG := ?V : nat |- _ => let rec f x n := lazymatch x with | S ?X => f X (S n) | ?E => is_evar E; let Gn := fresh "Gn" in assert (goalNumber n V) as Gn by exact (GoalNumber n V); move Gn at top; let H := fresh in set (H := E) in NG; instantiate (1 := (S ltac:(clear))) in (Value of H); subst H; clear NG end in f V 1 end ..]; [> lazymatch goal with NG := ?V : nat |- _ => instantiate (1 := 0) in (Value of NG) end; exact I | ..].
Definition argindex(n : nat)(t : Type)(Admit : forall T, T) : t. Proof. intros. apply Admit. Qed. Ltac remove_argindexes n f := match f with | context[?C] => lazymatch C with (argindex n ?T _) => lazymatch (eval pattern C in f) with ?F _ => let a := fresh "a" in eval cbn beta zeta in (fun (a : T) => ltac:(let b := (eval cbn beta in (F a)) in let r := remove_argindexes (S n) b in exact r)) end end | _ => f end. Load "numbergoals.v". Tactic Notation "abstracted" "as" ident(result) tactic3(tac) := refine (let result := _ in _); let dummy := constr:( ltac:( let Admit := fresh in intro Admit; let f := (eval cbn beta zeta in ltac:(unshelve tac; number_goals; lazymatch goal with | _ : goalNumber ?n _ |- _ => apply (@argindex n _ Admit) end)) in let r := remove_argindexes 1 f in instantiate (1 := r) in (Value of result); exact I ): (forall T, T) -> True) in idtac. (**********************************************************************) Variable P : nat -> nat -> Type. Variable Q : nat -> nat -> nat -> Type. Variable R : Type. Goal forall a b c, Q a b c -> (forall (x t y z : nat), P x t -> Q x y z -> R) -> True. Proof. intros a b c H0 H. abstracted as H' eapply H with (2 := H0). exact I. Qed.
- Re: [Coq-Club] specialize a subset of the parameters of a hypothesis, Pierre Courtieu, 01/08/2016
- Re: [Coq-Club] specialize a subset of the parameters of a hypothesis, Jonathan Leivent, 01/08/2016
- Re: [Coq-Club] specialize a subset of the parameters of a hypothesis, Pierre Courtieu, 01/09/2016
- Re: [Coq-Club] specialize a subset of the parameters of a hypothesis, Jonathan Leivent, 01/09/2016
- Re: [Coq-Club] specialize a subset of the parameters of a hypothesis, Pierre Courtieu, 01/11/2016
- Re: [Coq-Club] specialize a subset of the parameters of a hypothesis, Jonathan Leivent, 01/11/2016
- Re: [Coq-Club] specialize a subset of the parameters of a hypothesis, Jonathan Leivent, 01/12/2016
- Re: [Coq-Club] specialize a subset of the parameters of a hypothesis, Pierre Courtieu, 01/13/2016
