coq-club - Re: [Coq-Club] cbv evaluation in Coq?
  • From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] cbv evaluation in Coq?
  • Date: Wed, 13 Jan 2016 15:26:55 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
  • Ironport-phdr: 9a23:E8VpUxcjf8cIfPMOw/7gqkcTlGMj4u6mDksu8pMizoh2WeGdxc6/ZR7h7PlgxGXEQZ/co6odzbGG7eawBidaut6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDsvc2MKF8TzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZB18RmBBFGRSNzwv3VJ38qDCy4u902S2bO8LyTKsoQhy46K1hRQX0iz0KPTQ06nqRjMgm3/ETmw6ouxEqm92cW4qSLvcrJq4=
I think the problem can already be shown without template-coq:
Definition bb := bool.
Definition demo (t:True) : bb := match t with I => true end.
Print demo.
(* fun t : True => match t return bb with
| I => true
end *)
Eval compute in demo.
(* fun t : True => match t return bool with
| I => true
end *)
(* bb, which is under a lambda, became bool *)
The reference manual states:
The call-by-value strategy is the one used in ML languages:
the arguments of a function call are evaluated first, using
a weak reduction (no reduction under the λ-abstractions).
So, if I understand that correctly, cbv should not reduce under lambdas and this is a bug in cbv.
On 01/13/2016 02:49 PM, Randy Pollack wrote:
The certicoq project (https://www.cs.princeton.edu/~appel/certicoq/)
has recently been discussing what "evaluation" should mean for Coq
programs (including programs with axioms). I noticed the following
Coq behavior that surprised me. I apologize for the long email, which
I attempt to make self contained. Consider the program [demo]
To look beneath Print form, I use Malecha's quoting plugin,
template-coq (https://github.com/gmalecha/template-coq/tree/coq-8.5).
First quote the program
Quote Recursively Definition p_demo := demo.
Print p_demo.
p_demo =
PType "Coq.Init.Logic.True"
(("True", {| ctors := ("I", tRel 0, 0) :: nil |}) :: nil)
(PType "Coq.Init.Datatypes.bool"
(("bool",
{| ctors := ("true", tRel 0, 0) :: ("false", tRel 0, 0) :: nil |})
:: nil)
(PConstr "Top.bb" (tInd (mkInd "Coq.Init.Datatypes.bool" 0))
(PConstr "Top.demo"
(tLambda (nNamed "t") (tInd (mkInd "Coq.Init.Logic.True" 0))
(tCase 0
(tConst "Top.bb")) (tRel 0)
((0, tConstruct (mkInd "Coq.Init.Datatypes.bool" 0) 0)
:: nil))) (PIn (tConst "Top.demo")))))
: program
This quotes everything in the Coq context that is hereditarily used in
the toplevel program. The toplevel program (item "PIn") is just the
defined constant (tConst "Top.demo"). The definiens of "Top.demo"
(bound in the quoted context as 'PConstr "Top.demo"') is
(tCase 0
:: nil)))
Notice the defined constant (tConst "Top.bb") under a lambda in the
mechanically generated return predicate of the Case statement.
Now we quote the cbv evaluated program
Quote Definition qcbv_demo := Eval cbv in demo.
Print qcbv_demo.
qcbv_demo =
(tCase 0
(tInd (mkInd "Coq.Init.Datatypes.bool" 0)))
(tRel 0)
((0, tConstruct (mkInd "Coq.Init.Datatypes.bool" 0) 0) :: nil))
: term
The instance of (tConst "Top.bb") under a lambda has been unfolded to
its definiens, (tInd (mkInd "Coq.Init.Datatypes.bool" 0)).
This is not the behavior I expect for Eval cbv. What is the
specification of cbv for Coq?
Best,
Randy
