- From: Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Is it possible to rewrite under binders?
- Date: Wed, 27 Jan 2016 08:39:12 +0000
- Accept-language: en-US, en-GB
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.mailfrom=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.helo=postmaster AT uidappmx05.nottingham.ac.uk
- Ironport-phdr: 9a23:uV/Nbh/YZGvEbP9uRHKM819IXTAuvvDOBiVQ1KB92+kcTK2v8tzYMVDF4r011RmSDdqds6sP0rCK+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStGU1538jrrus7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JsKWqLjOq88ULZwDTI8Mmlz6teh/U3IShLK7X8BWE0XlABJCk7L9kepcI32t37Gtu1nwzWXO4XfSaw5Xzej9axrAEvUiCAdLCI09if+jtB9iqFauhmhjxp435LVZo6VPf84d6ibYNBMFjkJZdpYSyEUWtD0VIAIFedUZes=
Indeed you need functional extensionality which isn’t provable in coq.
Imho this is a bug, but one which isn’t easy to fix.
We suggested a solution a while ago (called Observational Type Theory) but this was never implemented in any real system. Now there is something better coming up, see Coquand et al’s work on Cubical Type Theory.
Cheers,
Thorsten
From: <coq-club-request AT inria.fr> on behalf of Hugo Carvalho <hugoccomp AT gmail.com>
Reply-To: "coq-club AT inria.fr" <coq-club AT inria.fr>
Date: Tuesday, 26 January 2016 18:56
To: coq-club <coq-club AT inria.fr>
Subject: [Coq-Club] Is it possible to rewrite under binders?
Hi Club!
Consider the following goal:Doesn't seem like you can rewrite "x+1" into "S x" (since you can't introduce "x" into the context, you can't refer to it in order to instantiate an equality you'd use to rewrite)... Is this the case? Is this goal unprovable without relying on axioms (functional
extensionality does the trick, of course)?
This message and any attachment are intended solely for the addressee and may contain confidential information. If you have received this message in error, please send it back to me, and immediately delete it. Please do not use, copy or disclose the information contained in this message or in any attachment. Any views or opinions expressed by the author of this email do not necessarily reflect the views of the University of Nottingham. This message has been checked for viruses but the contents of an attachment may still contain software viruses which could damage your computer system, you are advised to perform your own checks. Email communications with the University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club] Is it possible to rewrite under binders?, Hugo Carvalho, 01/26/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Jonathan Leivent, 01/26/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Emilio Jesús Gallego Arias, 01/26/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Pierre-Yves Strub, 01/27/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Thorsten Altenkirch, 01/27/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Jonathan Leivent, 01/27/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Guillaume Melquiond, 01/27/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Guillaume Melquiond, 01/28/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Pierre-Marie Pédrot, 01/28/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Jonathan Leivent, 01/28/2016
- Re: [Coq-Club] Is it possible to rewrite under binders?, Guillaume Brunerie, 01/28/2016
