- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Universes in Modules
- Date: Sat, 30 Jan 2016 16:41:01 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ob0-f173.google.com
- Ironport-phdr: 9a23:DJ1LXRJqiDNSF1VCfNmcpTZWNBhigK39O0sv0rFitYgULvXxwZ3uMQTl6Ol3ixeRBMOAu60C07qd6v24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35vxj7D5osCLKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBnxyOGcsocbvqBPrTA2V53JaXH9AwTRSBA2QzhjhWZG5nTH9rfE1jCuTJsrwQqozQi/zx6huQR7sziwAMmhqoynslsVsgfcD81qarBtlztuMbQ==
Are you asking: "How do I generate fresh (monomorphic?) universe variables every time I mention a particular module type in an argument list?"
Universe variables are either global, or local to a definition. (There's a strange intermediate state when you have section-local polymorphic universes, which, if I understand correctly, are considered global while inside the section, but are replaced by definition-local universes when closing the section.) Universe variables can't be local to modules/module types, and I don't think there's any way to get Coq to generate new universes on a Module declaration line, though I may be wrong.
The closest I could get is the following. Is this something like what you want?
Set Universe Polymorphism.
Set Printing Universes.
Monomorphic Universe UT.
Module Type Uni.
Monomorphic Parameter U : Type@{UT}.
Axiom U_elim : U -> Type@{UT}.
Coercion U_elim : U >-> Sortclass.
Global Arguments U_elim / .
Global Arguments U / .
End Uni.
Module U0 <: Uni.
Monomorphic Definition U := Type.
Definition U_elim : U -> _ := fun x => x.
End U0.
Module U1 <: Uni.
End U1.
Module Option (Import U : Uni) (Import U' : Uni).
Inductive option (T : U.U) :=
| None
| Some (_ : T).
Record prod (A : U.U) (B : U'.U) := pair { fst : A ; snd : B }.
End Option.
Module Option0 := Option U0 U1.
On Sat, Jan 30, 2016 at 3:58 PM, Gregory Malecha <gmalecha AT gmail.com> wrote:
Hello --I'm wondering if there is a clean way to to make a module type that carries a universe. What I would ideally want to do is something like:Module Type Uni.Universe U.End Uni.Module Option (U : Uni).Inductive option (T : Type@{U.U}) : Type :=| None| Some (_ : T).End.But the universe U is not accessible. My attempt, which I do not think actually works is something like this:Module Type Uni.Universe U.Parameter type : Type@{U}.End Uni.Module Option (U : Uni).Definition U := ltac:(match type of U.type with | ?T => exact T end).Inductive option (t : U) : Type :=| None| Some (_ : T).End Option.As far as I can tell though, the universe [U] seems to be fixed, and does not vary between different instances of the module type.Does anyone know of a way to achieve this?Thanks.--gregory malecha
- [Coq-Club] Universes in Modules, Gregory Malecha, 01/30/2016
- Re: [Coq-Club] Universes in Modules, Jason Gross, 01/30/2016
- Re: [Coq-Club] Universes in Modules, Gregory Malecha, 01/31/2016
