coq-club - Re: [Coq-Club] Tactic inlining?
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Tactic inlining?
  • Date: Sun, 31 Jan 2016 21:31:13 -0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=bziliani AT famaf.unc.edu.ar; spf=None smtp.mailfrom=bziliani AT famaf.unc.edu.ar; spf=None smtp.helo=postmaster AT famaf.unc.edu.ar
  • Ironport-phdr: 9a23:G4E3XxGT7Q0lVKdaq921HZ1GYnF86YWxBRYc798ds5kLTJ75oMqwAkXT6L1XgUPTWs2DsrQf27WQ6/GrADxbqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7/0o8yYOlUTzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IeezAcq85Vb1VCig9eyBwvZWz9EqLcQzazXwFGk4SjxAAVwPC9VTxWor7mir8rOt0nieAa57YV7cxDB6v864jeh7siS4BNnZt+nPWjs15iqNzrhukrhI53ojfJoyZKbx3ZPWOLpshWWNdU5MJBGR6CYSmYt5KVrJZMA==
D'ough, I even saw the discussion (I think in coq-dev). Thanks!
On Sun, Jan 31, 2016 at 9:28 PM, Maxime Dénès
<mail AT maximedenes.fr>
wrote:
> Hi Beta,
> The syntax was changed to :
> Definition test : nat := ltac: (exact 1).
> I believe it is documented in the CHANGES file.
> Cheers,
> Maxime.
> On 02/01/16 01:26, Beta Ziliani wrote:
>> Dear all,
>> In Coq 8.5beta1 it is possible to write the following code:
>> Definition test : nat := $( exact 1 )$
>> However, in Coq 8.5 it complains saying that $( is an undefined token.
>> Did it change? Is it in the ref-man? Where?
>> Thanks a lot,
>> Beta
