coq-club - Re: [Coq-Club] batch compilation and warnings
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] batch compilation and warnings
  • Date: Thu, 4 Feb 2016 07:51:24 -0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=beta.ziliani AT gmail.com; spf=Pass smtp.mailfrom=beta.ziliani AT gmail.com; spf=None smtp.helo=postmaster AT mail-ig0-f178.google.com
  • Ironport-phdr: 9a23:24MGZBDBys6j+UKQLqlFUyQJP3N1i/DPJgcQr6AfoPdwSP78psbcNUDSrc9gkEXOFd2CrakU1KyM6+u6ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokbrqsMeLKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46Fp34d6XK77Z6U1S6BDRHRjajhtpZ6jiR6WZgyWrlAYT29exhFPGk3O6Azwdpb3qCrz8ORnjnq0J8rzGJo5RT3q3aZvSRbuiW9TPTMl+SfFi8hxhaRaiB2krh17hYXTZdfGZ7JFYqrBcIZCFiJ6VcFLWnkEW9vkYg==
On Feb 4, 2016 7:11 AM, "Ralf Jung" <post AT ralfj.de> wrote:
> Hi,
> > I asked this question because this would be very useful to have such an
> > option. If there is currently no way for batch compilation to print
> > warnings, then consider this as a feature request. Such a feature is
> > provided by compilers like gcc, ocamlc, etc. It helps maintaining and
> > improving developments. It is especially useful for big ones. Each new
> > release of Coq comes with new features but also with new warnings and
> > deprecated constructions. Instead of discovering that a development
> > breaks with a new release, printing warnings would enable users to
> > anticipate changes and improve their developments. Currently, in Coq,
> > warnings are discovered in interactive mode only. This makes impossible
> > to locate warnings in big developments spread other many files that are,
> > most of the time, run on batch mode only. So, would it be possible to
> > include such an option in the next 8.5pl1?
> I can second this, having warnings when running "make" would be helpful.
> However, there also would have to be some work on which warnings are
> printed. For example, when doing automation involving ssreflect's
> "case", one often gets annoying warnings like "nothing to inject", which
> are very hard to avoid in generic tactics. (Or maybe my ltac-foo is just
> lacking.)
> Other compilers typically allow choosing the set of printed warnings
> being configurable via "-Wflag". That would be helpful, and probably
> necessary, when enabling printing of warnings for batch compilation.
It's called "sed" :-P
> Kind regards,
> Ralf
