- To: coq-club AT inria.fr
- Subject: [Coq-Club] Coq 8.5 extractor bug
- Date: Tue, 9 Feb 2016 20:11:34 +0900
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pi8027 AT gmail.com; spf=Pass smtp.mailfrom=pi8027 AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f178.google.com
- Ironport-phdr: 9a23:DRhiWx8uaoBVFv9uRHKM819IXTAuvvDOBiVQ1KB90OIcTK2v8tzYMVDF4r011RmSDdqdsKoP0bCempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRciJ14/tjaibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MlZFK7+Yq4QTLpCDT1gPXpmytfssEzgRBmS5nofVS0tmxlBDBXO7BCyCo/w4nOg6cJy3SCbOYv9SrViCmfq1LtiVBK90HRPDDU+6myC0sE=
Hello,
I found an extracted code that can't be typed in OCaml and Haskell.
This issue happens on Coq 8.5, however, it can't be reproduced in Coq
8.5 beta 3.
For more details, please see attached file.
Thanks,
Kazuhiko
Record rec := { T :> Type; _ : T; _ : (T -> T) * T; }. Definition Rec := Build_rec. Module Type Sig. Parameter tt' : Rec unit tt ((fun x => x), tt). End Sig. Module Mod : Sig. Definition tt' := tt. End Mod. Definition x := match Rec unit tt ((fun x => x), tt) as T return T -> T with Build_rec _ _ (f, _) => f end Mod.tt'. Extraction Language Ocaml. Extraction "x.ml" x. Extraction Language Haskell. Extraction "x.hs" x.
- [Coq-Club] Coq 8.5 extractor bug, Kazuhiko Sakaguchi, 02/09/2016
- Re: [Coq-Club] Coq 8.5 extractor bug, Jacques-Henri Jourdan, 02/09/2016
