- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Easier way to close the "Find/Replace" panel in coqide
- Date: Wed, 17 Feb 2016 17:09:48 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sdconsta AT syr.edu; spf=None smtp.mailfrom=sdconsta AT syr.edu; spf=None smtp.helo=postmaster AT smtp1.syr.edu
- Ironport-phdr: 9a23:6MOVNBGM+73jKbudaa3pcZ1GYnF86YWxBRYc798ds5kLTJ75pMuwAkXT6L1XgUPTWs2DsrQf27WQ7/6rADZRqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7/0p8OYOl8ZzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZB34dlQZUSwPC6grmV531v2OureZ23y+BIcTeVqEuHzmu8vE4G1fTlC4bOmthoynsgctqgfcDrQ==
Excellent, thanks!
~Scott
On Wed, Feb 17, 2016 at 4:50 PM, Tej Chajed <tchajed AT mit.edu> wrote:
The Escape key will also close that panel.On Wed, Feb 17, 2016 at 4:48 PM, scott constable <sdconsta AT syr.edu> wrote:Hi All,I haven't been able to discover a convenient way to close the Find/Replace panel in CoqIDE on OSX. I can hit cmd+F to open the panel, but hitting cmd+F again will not close it. It seems that the easiest way to close Find/Replace is to detach the panel into a separate window, and then close that window. Am I missing something?Thanks in advance,~Scott Constable
- [Coq-Club] Easier way to close the "Find/Replace" panel in coqide, scott constable, 02/17/2016
- Re: [Coq-Club] Easier way to close the "Find/Replace" panel in coqide, Tej Chajed, 02/17/2016
- Re: [Coq-Club] Easier way to close the "Find/Replace" panel in coqide, scott constable, 02/17/2016
